02 PSM bugeye WRX sedan auto
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by MNSnoDrifter, Jun 15, 2016.
  1. MNSnoDrifter
    I'm parting out a 2002 PSM WRX sedan auto...will get a list soon. Hit me up with what you need.
  2. MNSnoDrifter
  3. MNSnoDrifter
    • EJ20 Longblock - $750/obo (was rebuilt, don’t know who did it)
    Short block - $400
    Heads - $400
    • Intake manifold $25/obo
    • Valve covers - $50/obo
    • Mishimoto radiator $225/obo
    • Mishimoto Trans cooler with hose $50/obo
    • Sport JDM TD05 turbo 175 obo
    • Silicone Inlet $50/obo
    • Silicone top and bottom radiator hose $40/obo
    • Front 02 sensor $40/obo
    • Starter $30/obo
    • Alternator $40/obo
    • 2 AC pumps $50/ea/obo
    • 2 Power steering pumps $50/ea/obo
    • Power steering reservoir $20/obo
    • Engine harness $75/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • Stock WRX flywheel $35/obo
    • Aftermarket Down pipe $75/obo
    • EBAY burnt tip Catback $120/obo
    • Exhaust manifold $40/obo
    • Suspension (stock struts & springs) - $200/obo
    • Front and rear sway bar $20/ea/obo
    • Stock WRX rims w/tires $200/obo
    • 5x100 hub assembly all four $100/obo
    • ABS sensor $20/ea/obo
    • Auto trans 600/obo
    • Rear Diff $75/obo (should be a 4.11)
    • Auto driveshaft $120/obo
    • Axles $25/ea/obo
    • Front bumper $75/obo
    • Rear bumper $50/obo
    • Doors $60/ea/obo
    • RS hood $75/obo
    • Driver headlight $25.00/obo
    • Tail lights $40/obo
    • Side skirts $50/obo
    • Main harness + cluster $750/obo
    • Front seats $80/obo
    • Rear seats $75/obo
    • Steering wheel $50/obo
    • center console $20/obo
    • carpet $40/obo
  4. thomas franz
    How is the rear bumper? any cracks or paint chips? Also, is there any tears in the driver seat?
  5. MNSnoDrifter
    Rear bumper is a bit beat up, and seat looks good except the wear and tear from getting in and out
  6. Quinn
    Quinn Well-Known Member
    What are the tires? and condition on the wheels?
  7. MNSnoDrifter
    tires are weathered, wheels are in decent shape little bit of corrosion on a few of them
  8. Hamuga
    Hamuga Well-Known Member
    I would like the rear drivers side door!
    Also just to check do you have the carpet for the trunk?
    Thank you.
  9. MNSnoDrifter
  10. mbird
    mbird Member
    I'm interested in all of the exhaust parts you have left and sway bars. Thanks
  11. tangledupinblu
    Any idea of how many miles are on the longblock Mikey?
  12. MNSnoDrifter
    Exhaust is still available, and only have F sway bay left.
    I was told engine was rebuilt and ready to run once all the little stuff got hooked up
  13. MNSnoDrifter
    and sorry, have Exhaust manifold, up pipe, Down pipe, and cat back....and I'll look around to see if we have another rear
  14. Scott
    Scott Well-Known Member
    how are the pass. side doors?
  15. MNSnoDrifter
    Pass front is pretty good, a guy is coming tomorrow to get a door, but can't remember which one
  16. Hamuga
    Drivers rear door.
    Thanks!
    MNSnoDrifter likes this.
  17. Hamuga
    MNSnoDrifter is awesome.
    Got the door, super nice!
    Thank you!
  18. MNSnoDrifter
    UPDATE - parts added
    Short block - $400
    Heads - $400
    • Valve covers - $40/obo
    • Mishimoto radiator $225/obo PENDING
    • Mishimoto Trans cooler with hose $50/obo PENDING
    • Sport JDM TD05 turbo $175/obo
    • Starter $30/obo
    • AC pump $50/obo
    • Power steering reservoir $20/obo PENDING
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • Stock Up-pipe - $15 Added
    • Front sway bar $20/obo
    • Auto trans $600/obo
    • Axles $20/ea/obo
    • Cusco subframe brace - $40 Added
    • Calipers - $20/ea Added
    • Drilled & Slotted rotors - $60 Added
    • Doors $60/ea/obo
    • RS hood $75/obo
    • Wiper motors - $30 Added
    • Wiper arms - $10 Added
    • Grill inserts WRB - $10 Added
    • carpet $40/obo
  19. pleiades
    pleiades Well-Known Member
    Is that Cusco subframe brace for the front or rear?
  20. MNSnoDrifter
  21. pleiades
    PM'd on the brace
  22. derp
  23. MNSnoDrifter
    UPDATE
    Short block - $400
    Heads - $400
    • Starter $30/obo
    • AC pump $50/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • Axles $20/ea/obo
    • Drilled & Slotted F rotors - $50
    • Slotted R rotors - $40
    • Doors $60/ea/obo (FL. FR, RR)
    • RS hood $75/obo
    • Front seats $65/obo
    • Rear seats $45/obo
    • Center console $20/obo
    • Carpet $40/obo
    • Front Dash - $50
  24. MNSnoDrifter
    UPDATE
    • EJ20 Longblock - $600/obo
    Short block - $400
    Heads - $300 (no cracks in spark plug holes, probably could use a valve job)
    • Starter $30/obo
    • AC pump $50/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • Rear Axles $20/ea
    • RS hood $75/obo
    • Wiper arms - $10
    • Main harness + cluster $500/obo
    • Carpet $40/obo
    • Front Dash - $50
  25. Just-someone
    Just-someone Well-Known Member
    Both fenders still good ?
  26. MNSnoDrifter
    both fenders are gone
  27. Threshld1
    Threshld1 Well-Known Member
  28. MNSnoDrifter
    UPDATE ......and a few parts added
    • Short block - $400
    • Heads - $300 (no cracks in spark plug holes, probably could use a valve job)
    • Intake manifold - $25/obo
    • Side feed TGV's - $50 ADDED
    • Stock Injectors - $100/obo ADDED
    • Mishimoto radiator - $225/obo
    • Mishimoto Trans cooler with hose - $50/obo
    • Silicone top and bottom radiator hose - $40/obo
    • Starter - $30/obo
    • Alternator - $40/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • ABS sensors $20/ea/obo
    • Auto trans $500/obo
    • Auto driveshaft (good for someone doing a 6SP swap) $120/obo
    • Rear Axles $20/ea
    • Rear bumper $40/obo
    • RS hood $75/obo
    • Driver headlight $20.00
    • Wiper motors - $20
    • Wiper arms - $10/ea
    • Main harness + cluster $400/obo
    • WRX ECU - $100/obo ADDED
    • Front seats $50/obo
    • Rear seats $30/obo
    • Carpet $30/obo
    • Front Dash - $30
  29. Eazy_E_Rich
    Eazy_E_Rich Well-Known Member
    Drivers door window switches available?
    I would also take the center console.
  30. MNSnoDrifter
    Center console, yes. ..I believe the driver window switch is gone
  31. Navar Hren
    Navar Hren Active Member
    Is the carpet in good shape? Any tears? Same about the rear seat. Good shape?
  32. MNSnoDrifter
    • Starter - $30/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • Rear Axles $20/ea
    • RS hood $75/obo
    • Rear upper seat portion $20/obo
    • Front Dash - $30
  33. Scott
    Did you ever fire or her the engine running?
  34. MNSnoDrifter
    no, came in still needing a few things put on before it was ready for startup
  35. Scott
    So a crap shoot as to if it's good or not then.
  36. MNSnoDrifter
    only the short block is left
  37. Scott
    I have two engines that are **** now. Just looking for a replacement.
  38. MNSnoDrifter
    gotcha, was gonna try and put some good heads on the block and do a compression test if we ever have time
  39. MNSnoDrifter
    when we did a compression test on the full motor it came out bad...but it could have been just the heads
  40. MNSnoDrifter
    • Top feed TGV's - $30
    • Stock fuel rails - $25 ADDED
    • Valve covers - $30/obo
    • Mishimoto Trans cooler with hose - $40/obo
    • Silicone lower radiator hose - $15/obo
    • Starter - $30/obo
    • Stock bpv $25/obo
    • OEM BCS $20/obo
    • x2 Coolant ressevoir - $20/ea ADDED
    • Coil packs - $20/ea ADDED
    • Auto trans $400/obo
    • Auto driveshaft (good for someone doing a 6SP swap) $100/obo
    • Rear Axles $20/ea
    • Drilled & Slotted F rotors - $40
    • Doors $60/ea/obo (RR)
    • RS hood $75/obo PENDING
    • Auto Main harness + cluster $200/obo
    • Front Dash - $30
    • Stock clock - $15 ADDED
  41. scoob
    scoob Well-Known Member
    alternator tensioner?
  42. Scott
    I have everything but the pully.
  43. scoob
    =this one doesn't come with a pulley. this is the one between the ps pump and alternator
  44. Scott
    This one?
  45. Scott
    Different view
