02 PSM bugeye WRX sedan auto
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by MNSnoDrifter, Jun 15, 2016.
  1. scoob
    scoob Well-Known Member
    the piece that was taped up that long bolt
  2. Scott
    Scott Well-Known Member
    then yes I have one for sale.
  3. scoob
    how muuch and where you located
  4. Scott
    Lake Elmo MN. 55042 $30
  5. scoob
    how long will you be up for? i get off work at 9
  6. Scott
    What time would that put you here? I get up at 4:30 am. You could pick it up tomorrow in South St. Paul off Hardman Ave and 494
  7. scoob
    i work until 9 every night
  8. Scott
    what time could you be to my house?
  9. scoob
    tonight wont work I ran into another issue but tomorrow might work
    keep you posted
  10. Scott
    no worries. I have decided to keep all my parts till after I decide if I am going to fix my wrx or sell it
  11. Silky21L
    Silky21L Well-Known Member
    Knock sensor available?
  12. Scott
    no sorry
  13. MNSnoDrifter
    He was probabluy asking me, Yeah it should be, I'll will check to make sure
    Ntxhuav_Khang likes this.
  14. SimRacer
    SimRacer Well-Known Member
    did someone already buy the front bumper?
  15. MNSnoDrifter
  16. MNSnoDrifter
    UPDATE ......and a few parts added prices dropped
    • Short block - $250
    • Intake manifold - $20
    • Top feed TGV's - $25
    • Stock fuel rails - $20
    • Stock Injectors - $40
    • Valve covers - $30/obo
    • Mishimoto Trans cooler with hose - $30
    • Silicone lower radiator hose - $10
    • Starter - $25
    • Alternator - $30
    • Power steering reservoir $15
    • Stock bpv $25
    • OEM BCS $20/obo
    • Metal Coolant ressevoir x2 - $20/ea ADDED
    • Coil packs - $20/ea
    • stock fuel pump assembly - $50 ADDED
    • 5x100 LR hub assembly w/ lateral links - $50
    • ABS sensors $20/ea/obo
    • Auto trans $300/obo
    • Auto driveshaft (good for someone doing a 6SP swap) $100/obo
    • Rear Axles $20/ea
    • Power steering rack x2 (one needs some boots, the otehr needs a driver side tie rod - $40/ea ADDED
    • Rear Subframe (good upgrade for you older RS guys) - $50 ADDED
    • Calipers - $20/ea Added
    • Drilled & Slotted F rotors - $40
    • Slotted R rotors - $40
    • Rear bumper $40/obo
    • Doors $60/obo (RR)
    • RS hood $75/obo
    • Driver headlight $20.00
    • Wiper motors - $20
    • Wiper arms - $10/ea
    • Auto Main harness + cluster $100/obo
    • Rear upper seat portion $20/obo
    • Center console $20/obo
    • Front Dash - $25
    • Stock clock - $15
    20161001_221107.jpg 20161002_210758.jpg 20161001_221118.jpg 20161002_210908.jpg 20160831_224320.jpg 20160831_224556.jpg
  17. SimRacer
    what condition are the rotors? I may be interested
  18. Krazylegz1485
    Pic of RR door?
    Also, plans with shell when done?
  19. tangledupinblu
    Sedan and wagons have different doors mang!
  20. Krazylegz1485
    Not when you put sedan quarters on a wagon, mang!
    tangledupinblu and MNSnoDrifter like this.
  21. MNSnoDrifter
    I believe Usable, you can check them out sometime If you'd like
    ahh...tomorrow I can get a pic, and shell it gone .....would have sold it for $100
    Krazylegz1485 likes this.
  22. SimRacer
    would you have a pic of them?
  23. Deathly
    Deathly Well-Known Member
    I have a wrb RL door that needs to be painted ill give you for free.
  24. MNSnoDrifter
  25. Krazylegz1485
    Really... I'll be sending you a message, sir!
    MNSnoDrifter likes this.
  26. MNSnoDrifter
    Door SOLD
  27. mbird
    mbird Member
    Is the coating on those backing plates just flaking or are they pretty rusted out?
  28. MNSnoDrifter
    Backing plates?
  29. Ntxhuav_Khang
    Driveshaft sold as well. :) thanks Mike.
  30. MNSnoDrifter
    Backing plates as in behind the rotors? I'll take a look but probably pretty rusted...gonna be hard to find a MN car that has clean, good plates!
  31. Weird0
    Weird0 Well-Known Member
    Looking for a WRX steering wheel. Any available?
  32. MNSnoDrifter
    I'll look, but don't think so
  33. Weird0
    Sounds good! Let me know, thanks!
  34. 02srp
    02srp Member
    How much for the rear passenger rear lateral link?
  35. MNSnoDrifter
    Didn't see a steering wheel
    Can do the whole thing for $40/obo
    • Short block (should be good, no shavings when we took off the oil pan) - $200
    • Intake manifold - $20 SOLD
    • Top feed TGV's - $25 SOLD
    • Stock fuel rails - $20 SOLD
    • Valve covers - $25/obo
    • Mishimoto auto Trans cooler with hose - $25
    • Starter - $20
    • Alternator - $25
    • Stock bpv $20
    • OEM BCS $20/obo
    • Metal Coolant ressevoir x2 - $15/ea
    • stock fuel pump assembly - $40
    • 5x100 LR hub assembly w/ lateral links - $40/obo
    • Auto trans $250/obo
    • Rear Axles $20/ea
    • Drilled & Slotted F rotors - $25
    • Slotted R rotors - $25
    • Rear bumper $30/obo
    • Doors $45/obo (RR)
    • RS hood $60/obo
    • Wiper motors - $10
    • Wiper arms - $5/ea
    • Auto Main harness + cluster $50/obo
    • Center console $15/obo
    • Front Dash - $15
    • Stock clock - $10
    ADDED
    • Timing Belt kit (installed, but never ran) - $125
    • Timing belt covers - $50 for the set
  36. MNSnoDrifter
  37. MNSnoDrifter
  38. silver03
    Timing belt kit-Gates? OEM?
  39. MNSnoDrifter
    UPDATE
    • Starter - $20
    • Alternator - $25
    • Stock bpv $20
    • OEM BCS $20/obo
    • Metal Coolant ressevoir - $15
    • Stock fuel pump assembly - $40
    • Rear Axles $20/ea
    • Power steering rack x2 (one needs some boots, the other needs a driver side tie rod - $40/ea ADDED
    • Rear bumper $25/obo
    • RR Doors $40
    • RS hood $45
    • Driver headlight $20.00 PENDING
    • Stock clock - $10
  40. MNSnoDrifter
    Kit sold tonight
  41. MNSnoDrifter
    Headlight SOLD
  42. SubeN'Siren
    SubeN'Siren Well-Known Member
    How about a fuel pump controller?
  43. MNSnoDrifter
    I'll have to look
  44. FEAR_NO_EVO
    FEAR_NO_EVO Member
    Short block still available?
  45. MNSnoDrifter
