02 wrx front tire squeek
Discussion in 'Modifications And Maintenance' started by thomas franz, Mar 12, 2014.
  1. thomas franz
    I recently replaced my camber bolts, wheel bearing, hub and ball joints on my driver side front wheel. I hear a squeeking like a wet rubber on wet rubber/metal. I cant find any rub spots and it seems to get worse the longer i drive. Any ideas? hub and bearing were pressed at a local shop and the ball joint/camber bolt was done by me. Could needing an alignment cause this?
