02 wrx metal chips in trans questions
Discussion in 'Modifications And Maintenance' started by xodad2, Jun 25, 2014.
  1. xodad2
    xodad2 Well-Known Member
    IMG_20140625_210025_764.jpg IMG_20140625_204645_724.jpg Just changed tranny fluid on my 02 wrx. I found a few chunks of metal on the plug. The chunks are about 1/16-3/32 of an inch. Is this normal or am I going to die... or trans problems soon?
    Pics
  2. JasonoJordan
    That does not look good in my none professional opinion
    pillboy, tehfuzz, T_riggidy and 2 others like this.
  3. xodad2
    It hasn't done any grinding or weird shifting. Just changed it because I want to make sure I have extra-s in there.
    Is there anyway to flush it? What can I use to flush it with?
    Hopefully tomorrow when I change the rear differential it will look better.
  4. xluben
    Not good if that screw was in there.
    pillboy, T_riggidy, EricS and 3 others like this.
  5. Nhibbs
    Nhibbs Well-Known Member
    Yeah I'm surprised you haven't felt or heard grinding...I would start preparing for trans failure even if you can still drive it for a while.
    T_riggidy and xodad2 like this.
  6. xodad2
    No screw in there, just used it for scale.
    But it sounds like i maybe screwed...
  7. Deride
    From what I have seen normal is like a fine powder on the magnet. You might want to start driving like grandma until you can find a replacement.
  8. xodad2
    Granny shifting mode engaged.:censored::banghead::facepalm::(
  9. EricS
    EricS Nooberator
    Wonder if that is gear parts or shift finger/synchro parts... Maybe start double-clutching if you want to extend life until you can get it pulled apart/swapped?
    xodad2 likes this.
  10. JasonoJordan
    to me looks like chips of gear.
    EricS likes this.
  11. pillboy
    I always thought the wear material in synchros was brass or bronze...something non-metallic.
  12. EricS
    EricS Nooberator
    Yeah you're right, I was being sloppy, what I was trying to say was the dog teeth on the gears/collars. So part of the synchro system, but not the synchros themselves :)
