I'm in process of returning a 05 Legacy Gt back to stock. This is a list of some of the parts, but I will keep adding more when they are off the car. Also feel free to make a reasonable offer. AVO FMIC, has some oxidation on the intercooler, the cast charge pipe has some scratches, which is pictured. Comes with GFB hybrid BOV. Also comes with the front bumper beam spacer so you will not have to cut the beam! Most bolts are provided, but a few more will be needed which can be picked up at a hardware store. I can also include a KS Tech 73mm intake for an additional charge. $600 $700with the KSTech intake KSTech 73mm intake with shield, comes with 2 heatshields 1 modified to work with a FMIC, and 1 for with out the fmic piping $150 Zeitronix E85 analyzer with GM sensor ( Red ) $160 Zeitronix ZT-2 wideband meter with hacker display ( Blue ) $ 210 If both Zeitronix modules are bought together, I will include the custom made mount which goes in place of the ash tray. AVO 380 ball bearing turbo has about 30k miles on it, comes with a oil line filter that mounts to the right side avcs banjo, and a turbo blanket $650 Cobb Access port V3 AP3-SUB-002 comes with bracket to mount to the radio, and a obd port splitter $475
Injector Dynamics 1000cc top feed injectors $400 Top feed Race development parallel fuel rails with aeroquip hoses and fittings, aeromotive adjustable fpr, connects to the stock steel feed and return fuel pipes $400 I would sell the injectors and fuel rail setup for $700
