06 STI turbo not boosting
Discussion in 'Modifications And Maintenance' started by Skarecrow, Feb 6, 2011.
  1. Skarecrow
    Skarecrow Well-Known Member
    Well... My car ran fine till I got lunch, then after heading out I noticed the turbo doesn't want to spool past 0.
    It has vacuum, and appears to drive fine off boost.... But uhhh... No boost.
    I'm not blowing smoke, or anything.
    I havnt had a chance to pop the hood and check all the hoses super proper... But does anyone have any guesses?
  2. idget
    Wastegate arm
  3. FuJi K
    how's it feel to drive an NA STi???? lol
    had my arm fall off and it was so fast! This was on my EVO3-16G back in the day. At least it boost creep to 14psi up top in the rpms.... lol
  4. Skarecrow
    Oh man... Na-STI is a drunk pig on hog farmer race day.
    I'm not a fan. Is this a hard fix?
  5. idget
    no, it's usually a c-clip... unless the arm broke... then you either fix the arm or replace the actuator depending on how it broke.
    sounds like you haven't looked at it yet?
  6. Skarecrow
    correct... been waiting to roll it into the garage so I can take a look, since I don't fully know what im looking for. I would rather it be warm :)
  7. Skarecrow
    So this is what I found....
    Does this look right to any of you?
  8. 03subyR
    03subyR Well-Known Member
    It looks normal, can you move the actuator arm? It should not move freely unless it's broken. Good luck.
  9. Skarecrow
    The answer to that question is yes. But it doesn't move super easily.
    How freely is freely? Lol.
  10. Back Road Runner
    How are all the hoses looking?
  11. Skarecrow
    Finally got the IC off today, all hoses look good, can't see anything hose wise that would be causing no spool. There was a a bit of oil in the turbo, but nothing that would or should freak me out. After I get all the hoses back on I figure I would see if it fell into some sort of limp mode without telling me. ((not sure if it's possible.. but anything is possible))
