07 ej25 into 97
Discussion in 'Modifications And Maintenance' started by KRYPTO, Apr 4, 2011.
  1. KRYPTO
    KRYPTO New Member
    Can I bolt a 2007 2.5 into my 97? Im thinking all i would need to do is swap sensors and maybe throttle bodies.
  2. Mr.Tran
    Mr.Tran Well-Known Member
    Search around online, I'm sure it can be done. However I'm thinking it's going to be a lot more complicated than that. Not to mention your dropping a more powerful motor into an aging chassis. I don't know what type of power your tranny etc. can hold. I'm assuming your talking about a turbo EJ25?
  3. Chux
    yes
    just thought I'd reply with a comparable amount of information.
  4. KRYPTO
    KRYPTO New Member
    would i need to swap ECU and harness out?
  5. KRYPTO
    KRYPTO New Member
  6. idget
    relevant username is relevant
  7. Mr.Tran
    I'm not trying to be mean but it seems you have a lot more research to do. Try looking on Nasioc and other forums, as well as trying the search function on here. BTW I wouldn't buy anything from that company!
  8. blackozone
    Yes, we have no bananas.
  9. JasonoJordan
    if my memory is correct didnt u have a thread some months ago about just bolting a 02 wrx motor into this car???
  10. Chux
    maybe
  11. blackozone
    It's uncertainly possible.
  12. idget
    It's a possible uncertainty that this is uncertainly unpossible.
  13. Threshld1
    Threshld1 Well-Known Member
    Yes, I put an 06 into my 97. But I swapped out the entire car wiring harness for the 06 harness (not just engine/ecu-the ENTIRE power/car harnesses) and modified/made connectors to interface with the windows/locks/hvac etc... Its a long ways away from just changing a few sensors. Lots of cutting/splicing. Not for the faint of heart.
  14. blackozone
    Did... did you just divide by zero?
