09 WRX short shifter better than the SPT?
Discussion in 'Modifications And Maintenance' started by ofspunk7, Jun 18, 2010.
  1. ofspunk7
    Nord' St Paul
    I got the SPT short shifter in my car off the lot. I noticed that there was very little difference between the SPT and stock set up. Has anyone had any luck with a better or more noticeable difference on 08+ WRX short shifters? I am doing some research, and althought this is not high on my list of stuff to upgrade, I might swap it out.
  2. predavore
    predavore Well-Known Member
    Southern 'Burbs
    I was told by the dealer... "aftermarket short shifters can cause damage to the transmissions". Don't really believe that, but either way I put an SPT short shifter in and took out the Agency Power one. I can tell the difference between the two, but I am fine with it. The aftermarket one seems to make the shifting notchy. For me, (at this point) it's not a race car. It's a grocery and kid hauling car...
  3. ofspunk7
    Nord' St Paul
    Yeah don't want notchy.
    Would swapping out the bushing be a better way to take care of this.... or make a more noticable difference?
  4. predavore
    Southern 'Burbs
    I had the solid shifter bushing in there and that probably made it worse. I ended up with the STi rear bushing and the STP shifter. Works great. Putting a lower profile shift knob on there helps too (just barely).
  5. ofspunk7
    Nord' St Paul
    yeah, well Perrin is having the father's day sale this weekend, so their bushing are $17. Not sure if i should go with it or just save my money
  6. predavore
    Southern 'Burbs
    If you put a stiffer bushing in (definately with the solid ones) you will get a lot more tranny noise in the cabin. That is very annoying.
  7. jmyhre05
    jmyhre05 Well-Known Member
    maple grove
    me and my buddy are both having shifting problems... almost like the linkage is off alittle... kinda hard to go into some gears, his is a 06 wrx and mine a 08 wrx... is this normal for other people or just random we both have the same problem? we both have stock shifters.
  8. JasonoJordan
    i didnt have a problem after putting fresh extras in it even with a kartboyshort shifter.
