09 WRX Suspension question
Discussion in 'Modifications And Maintenance' started by WRX 56308, Jul 1, 2011.
  1. WRX 56308
    WRX 56308 Member
    I've been looking to lower my WRX, slighty, with springs. I'd like to change the struts as well. That way I can just bolt up new units, instead of taking the factory ones off, changing springs, and putting them back on. It seems as though the KYB GR2 and AGX are the most common reccomendations. My question is, where can I find them? O'reilly, Summit, and a few other sites I've looked at don't offer them as an option for the 09. Thanks!
  2. ShortytheFirefighter
    Have you checked out the GT Worx kit from RaceComp Engineering? I heard that setup is the way to go. One of the members on here (subytek) has it and had nothing but good to say about it.
  3. WRX 56308
    WRX 56308 Member
    I'll check that out.
  4. Dirtyracin
    Dirtyracin Member
    I'll buy your factory struts :) I've been looking for some 09's
  5. 03subyR
    03subyR Well-Known Member
    GT Works or BC coilovers are the only good option for 08+. If you just want a drop than Swift springs are the way to go.
  6. Tekko
    Tekko Well-Known Member
    I have read good things about Epic Engineering springs and Koni inserts.
  7. MNGman
    MNGman Well-Known Member
  8. WRX 56308
    WRX 56308 Member
    If I get those, I'll be saving a bit longer. ;) I have relatives in St. Michael. If I make it down that way, I might take you up on that,
  9. syndromeofthedown
    syndromeofthedown BANNED
    I have the RCE Bilstein set-up as well. Couldn't ask for anything better. Mines a DD and absolutely LOVE these! Cloverleafs at 50+ :). I have a set of Eibach springs if anyone's interested. Cheap. Also have my stock 08 struts front and rear with stock 08 top hats.
  10. WREX
    WREX Member
  11. Musashi
    I have stock suspension on my Toyota Prius and I can do 55mph in the clover leafs going up and down. In addition to that the Fiat 500 205mm tires can do 62mph in the same leafs with easy. LOL
    If you're looking for better response get some low profile summer tires with stiffer sideways. Save the headache and keep your cheese in your pocket for seat time. Enjoy!
  12. WRX 56308
    WRX 56308 Member
    I have Dunlop SP Sport 01's that have to go on it. Just havent had time yet. Buying a house is eating it all up.
