1998 Forester JDM SF Forester EJ205 swap
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by Quinn, Jul 23, 2017.
  1. Quinn
    Quinn Well-Known Member
    Parting out this 98 forester with a jdm ej205 swap. Harness is merged. JDM 4.44 transmission and rear diff. Looks like GD STI Struts with lowering springs. JDM SF forester hood. Good Firestone Winterforce tires on 02-04 wrx wheels. Will add more pictures soon. 20370783_2011980635482370_1847226563_n.jpg Stock everything else.
  2. monsterenergy339
    monsterenergy339 Member
    Is the hood decent? Mine is dented and I need a new one.
  3. monsterenergy339
    Also need the left foam piece out of the back, left headlight and blinker, the rear wiper motor if it works, and a left tail light.
  4. Quinn
    I can pull the lights and it should have the foam piece, send me a pic so i know what it is. Ill test the wiper motor. Hood is a JDM hood with a scoop. asking 250
  5. monsterenergy339
    I'll let you know if I can get anything, all depends on how much I have left over from my head gasket repair job
  6. Quinn
    OKay sounds good
  7. scoob
    scoob Well-Known Member
    how much for the merged wire harness?
  8. Quinn
    400 for the harness
  9. blackozone
    Why part this out? Is something broken?
  10. Quinn
    Trans is missing 1st and 2nd gear. Clutch is roasted, Turbo seals are gone, brake pedal goes to the floor, and the shell is really rusty.
  11. blackozone
    Oh. That would do it.
    Krazylegz1485 and Quinn like this.
  12. Krazylegz1485
    My apologies if this is a lame request, but would you part with the front O2 sensor? If it's the same as a usdm part I guess.
  13. Quinn
    I can take a look!
    Krazylegz1485 likes this.
  14. Krazylegz1485
    Would certainly appreciate it. Thanks!
  15. scoob
    do you know what year the jdm harness is from or what year the motor is?
  16. Quinn
    I can search the trans code and that should help me give you a guesstimate
  17. scoob
    Ok that sounds great
  18. Quinn
    The trans code is ty755vb1aa Looks like the driveline and engine are from a 99-00 Turbo forester.
  19. retreif
    Is this the forester that the rear fenders were rolled with a t post?
  20. Quinn
    No? its not low enough for that to have been needed.
    Logan neikirk likes this.
  21. Quinn
    Engine, harness, exhaust, wheels/tires, hood, headlights gone
  22. GrawvyRobber
    GrawvyRobber Active Member
    Price on struts?
  23. Quinn
    Paint is coming off a bit, little rust, still nice and stiff, 150 with saggy butt spacers
