2000 forester Mass air code after head gaskets done
Discussion in 'Modifications And Maintenance' started by Foresterxt, Nov 14, 2013.
  1. Foresterxt
    Foresterxt Active Member
    Braindead Uh I mean Brainerd
    Ok been messing with this 2000 forester for over a year. My buddie Ryan Dwire helped me do the head gaskets and the damn thing tripped a mass air code and wont run right since we did them. We had done at least a dozen or more head gaskets together so we aren't stupid, but Im begging to think we made a stupid mistake.
    I have replaced the mass air sensor with a new one so there is no chance it could be bad. The worse part of all this is the 2000 is a year all of its own so I cant swap parts off my 02 :confused:
    Im begging to hate this car! :banghead:
    Anyone have any ideas??
    Thanks!
  2. thomas manship
    thomas manship Member
    I would start by checking to see if ur intake is clogged or not , filter stuffed up , something foreign in there . If nothin is found then it's probably time to get out ur digital multimeter and check the wires on maf for continuity . If someone doesn't beat me too it I'll see about bringing up a wiring diagram off subarunet
  3. Foresterxt
    Thanks! Ill double check the intake. Running conditions dont change with filter in or out. Wires are next. Thanks for a direction....
  4. Nuke
    Saint Paul
    actual cel code
  5. Ronnie@RSmotors
    Can you describe how it runs? What is the actual code? Does the code come on right after you clear it or after running for a bit?
  6. my97gt
    my97gt Member
    Preston, MN
    Have you checked the wires going into the maf?
  7. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    MSP
    Start with wires, and also check all air hoses. I've missed one before after removing intake. Maybe try a little MAF cleaner, delete code and see how it runs.
  8. ragdollslegacy
    ragdollslegacy Active Member
    twin cities
    did you purchase a new maf or a remanufactured one? also do you have a cold air intake?
