2000 impreza hub assembly. Need HElP
Discussion in 'Modifications And Maintenance' started by ADM_WRX, May 15, 2011.
  1. ADM_WRX
    ADM_WRX Active Member
    I was wondering for the impreza 2.5 hub assembly. Would the base model Subaru impreza or any other model's hub assembly work for a replacement?
  2. Threshld1
    Threshld1 Well-Known Member
    I believe they are the same but can not give you a definitive answer. You can use http://opposedforces.com/parts/ to compare part numbers between different years/models
  3. ADM_WRX
    Thanks I will check that out.
  4. FuJi K
    You have to go 2000+. 1999 and older doesn't have the clearance for the ABS ring found on the 00+ front axles.
    For the rear it's more forgiving because the ABS ring is on the hub not the axles like the front.
    ....so you're referring to the front or rear?
