2002 WRX | NF Performance | 10's on Snow Tires!
Discussion in 'Photo & Video Gallery' started by xluben, Oct 13, 2014.
  1. xluben
    Event: 1/4 Mile at Rock Falls Raceway
    Ambient Temp: 50F
    Elevation: 845ft
    Weather: Sunny and Clear
    Tires: 205/60R16 Blizzak WS70 Tires on 2002 WRX Wheels
    Car: 2002 WRX Sedan
    Tuner: Nuke @ NF Performance
    Transmission: 2012 STI 6 Speed
    1/4 Mile ET: 10.98s
    1/4 Mile Trap: 127.9mph
    60': 1.74s
    Target Boost: 30psi
    Target AFR: 11's
    Fuel: E85
    10.98s @ 127.9mph with 1.74s 60' (snow tires)
    Here's a video of an 11.1 and 10.9 sec pass:
    I ran 10.99 in this car at BIR last month, but I decided to take it out again yesterday. The changes since the last passes were: addition of KillerB header setup, changed to COBB AP, swapped in a welded rear diff, put the RS flat hood back on, and put on the stock wheels with winter tires (daily driven street car and it's been getting below freezing at night).
    I did a few shakedown passes with no launch just to see what it would trap. It was right around 128mph. Up from 126mph the last time, so I decided to give it a go. Ran 10.98 at 127.9 and 11.18 at 128.0 and then got the boot. 60' times were in the 1.7s range. Not as good as the 1.6's I was getting on the summer tires, but not terrible.
    Full Build Thread Here:
    http://mnsubaru.com/threads/xlubens-silver-2002-bugeye-wrx-sedan.43587/
    Engine:
    • OEM 2012 STI 2.5L Case
    • OEM 2012 STI Heads
    • OEM STI Nitrided Crank
    • OEM STI 11mm Oil Pump
    • OEM STI Gasket Set
    • CP 99.75mm 8.2:1 Pistons
    • Manley Turbo Tuff I Beam Rods
    • ACL Rod and Main Bearings
    • ARP Head Studs
    • GSC S1 Camshafts
    • GSC Beehive Springs w/Retainers
    • GSC Valve Seals
    • Torque Solution Motor Mounts
    Intake/Exhaust/Fuel:
    • KillerB Header and EWG Uppipe
    • TurboSmar 40mm EWG
    • HKS Downpipe
    • COBB CatBack Exhaust
    • Kinugawa TD06H 60-1 Turbo
    • TurboXS FMIC
    • TurboXS RFL BOV
    • GrimmSpeed MBC
    • 04 STI Fuel Pump Hanger
    • Walbro 255 Fuel Pump
    • ID2000cc Injectors
    Drivetrain/Transmission
    • OEM 2012 STI 6MT
    • OEM 2004 STI Driveshaft
    • OEM STI R180 Rear Diff Flange
    • Welded R160 Rear Diff
    • Anarchy Motive Shift Knob
    • Kartboy Short Shifter
    • Kartboy Front Shifter Bushings
    • Karboy Rear Shifter Bushings
    • Torque Solution Tranny Mount
    • Torque Solution Pitch Stop Mount
    • ACT HD Pressure Plate
    • ACT 4 Puck Unsprung Disk
    Suspension/Wheels:
    • 2002 WERX Wheels
    • 205/60R16 Blizzak WS70 Tires
    • Eibach Springs
    Interior/Electronics:
    • MapDCCD DCCD Controller
    • MapDCCD Vehicle Speed Sensor
    • ProSport EVO Boost Gauge
    • ProSport EVO Oil Pressure Gauge
    • AEM Wideband O2 Gauge
    • Odyssey Slim Battery
    Exterior:
    • RS Flat Hood
    • OEM Fog Light Covers
    • Removed Rear Wing
    Engine Bay:
    Kinugawa TD06H 60-1 Turbo:
    Firefighter181, bduncs, BroCo and 2 others like this.
  2. TMF
    Lol that's some nice driving! Imagine what you could on slicks...
    I want to see more of Brian's car...too bad he didn't get a good run.
  3. xluben
    Probably break more stuff.
    Yeah, it seemed pretty fast.
  4. ShortytheFirefighter
    This looks just like the one I keep seeing on Reddit...
    Mike and tehfuzz like this.
  5. derp
    i thought this was a 2.5rs?
    tehfuzz likes this.
  6. Mike
    Mike Well-Known Member
    Did you see that grand caravan running 10's?
  7. xluben
    Only has 10 upvotes. :(
    Apparently reddit only likes cars that look snazzy.
  8. Nhibbs
    Nhibbs Well-Known Member
    /r/subaru is stance central. Terrible place.
  9. xluben
    Yeah, pretty much. And the other car subreddits are mostly just drooling over cars they'll never afford.
    Nhibbs likes this.
  10. Nhibbs
    /r/cars and /r/autos is basically the same as reading the youtube comments on 1320 videos.
  11. xluben
    Yep. The only one I like is /justrolledintotheshop
  12. EricS
    EricS Nooberator
    It's aliiiiive! Hi Nibbler :)
    tehfuzz and Nhibbs like this.
  13. Ryan FailRad
    Nhibbs is BACK!! With a blue name instead of red lol
    Nhibbs likes this.
  14. Nhibbs
    I was very baaaaaaaaad. Needed to be punished.
    My name... Reek
    Ryan FailRad likes this.
  15. Musashi
    Well deserved buddy! All it took was a little patience and time to develop your driving skills and the rest is history. Working with the right people really does help achieve ones dreams. Nice nice job!
  16. xluben
    Thanks! Having a good team behind me is key! Wouldn't be here without NF.
    A little seat time doesn't hurt either. About 3 dozen passes this summer.
    Musashi, TMF and EricS like this.
  17. TMF
    Sooo did you ever get a chance to compare dyno plot with the old header vs. the killer b?
  18. xluben
    I don't think I ever plotted two logs on the same plot. I'll dig through some logs and see what I can come up with.
    It did trap 2mph faster though. So that's probably 25-30WHP more (on average, not necessarily peak).
    TMF likes this.
  19. Mike
    Nhibbs likes this.
  20. belalegosi
    belalegosi Well-Known Member
    That's pretty impressive!
    I've seen Subi guys with alot bigger builds struggling to keep it in 11s :eek:
  21. Firefighter181
    Firefighter181 Member
    That's pretty impressive. Good looking sleeper also!
  22. redheat86
    redheat86 Well-Known Member
    Hi Ben, maybe you mentioned somewhere else, but why the switch to AP?
  23. xluben
    A little bit of launch control and FFS goes a long way to getting the times down.
    Thanks!
    Easier tuning. The live tuning really speeds things up. No need to constantly stop the car and reflash. Easy for me to log on my own as well.
