2004 STI Partout
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by yuseforester, Jan 20, 2013.
  1. yuseforester
    Parting out a black 2004 STi.
    Has 83,656 miles. Motor runs great, except an exhaust leak in the bent header. Compression is even across the board.
    Timing cover removed to verify timing and inspect timing components - no damage present. NOT parting out motor.
    Was in a front end collision, but runs and drives; however the frame is bent pretty decently.
    No airbag deployment.
    I am open to offers, but be reasonable; please, save us both the time.
    My name is Yusef and I can be reached at 612-275-7398 via call or text- THANKS FOR LOOKING.
    Not that I have to say it, but Cash Only please.
    *Parts availability and listing subject to change as I get deeper into the part out!
    Drive line and all supporting components are spoken for. Wheels and Tires, front seats, gauge cluster, steering rack and steering wheel spoken for.
    Cold STi Start up - has leaking exhaust header so sounds rough. Idles great though. I will leave this hooked up for a while if anyone wants to come see it run.
    Oil Pressure reading - at idle is normal!
    Pictures:
    http://s1251.beta.photobucket.com/user/yuseforester/library/2004 STi Partout
    Part Out
    Engine - complete (Turbo is stock VF 39, has aftermarket heat wrapped up-pipe) $ 4,200.00 Engine Wiring Only -->Price Drop to $3800!
    Brembo Calipers front and rear $ 1,000.00
    (Later, there will be some rear conversion rotors and rear brake adapters available for all you 5X100 WRX or Forester guys!!)
    Brembo Front Rotors $ 40.00
    Front doors - (100 ea) - Prefer to sell as a set $ 200.00
    Rear doors - (100 ea) - Prefer to sell as a set $ 200.00
    Complete STI Interior (Door cards, front and rear seats, carpet, floor mats) $ 800.00
    Radio - Alpine CDA-105 $ 50.00
    Radiator Cooling Fans $25 ea $ 50.00
    Intercooler Sprayer Tank $ 45.00
    Sti Badged and winged trunk $ 350.00
    Passenger Air Bag $ 150.00
    Master Cylinder and Brake Booster $ 100.00
    Heater control $ 50.00
    Ecu $ 150.00
    tail lights 140 ea $ 280.00 SOLD
    Borla Turbo Back Exhaust $ 300.00 SOLD
    Triple Gauge Pod, no gauges $ 75.00
    Defi Gauge Set (Engine Temp DF039, EGT DF040, Oil Pressure DF037 - includes sensors) $ 150.00 -
    ABS Unit $ 100.00
    Heater Core $ 50.00
    Full Chassis wiring $ 100.00
    Immobilizer $ 75.00
    center console $ 50.00
    Radio Trim - CF $ 100.00
    Front Glass Offer
    Rear Glass Offer
    Rear Bumper $ 200.00
    Chassis Wiring $ 200.00
    Hood Scoop $ 50.00 scratched SOLD
    Splitter $ 50.00SOLD
    Fuel Pump Assy $ 40.00
    Driver Side Fender - Dinged up, but could be useful $ 10.00
    Stock Fender Braces $15 ea $ 30.00
    Driver Side Fog Cover $ 25.00
    All Interior Plastics (A, B, C Pillar etc) Offer
    Rear View Mirror $ 50.00
    Rear and front Drivers Wheel Well Inside Covers/Plastic $ 25.00 SOLD
    twiztid_rs and subaruordie like this.
  2. Mr.Tran
    Mr.Tran Well-Known Member
    If anyone picks up this motor and doesn't want the intercooler let me know!
  3. eterenity11
    eterenity11 Well-Known Member
  4. Ronnie@RSmotors
    Chassis wiring, is that everything else but the engine harness?
    Edit: saw the bulk harness listing. So ignore the question.
  5. yuseforester
    Sorry Ron; I meant to clarify that for you. bulkhead wiring is from the engine bay to the dash. Chassis wiring from the dash to the rear of the car.
  6. yuseforester
    For all those interested the Defi gauges are an older style D series - they are analog gauges. Pictures posted.
    I will respond to PM's shortly.
  7. mnnice
    mnnice Well-Known Member
    Sti seats you only have the rear? Or do your have front two seats as well?
  8. yuseforester
    Front seats are not available; but I do know someone who has some for sale...
  9. yuseforester
    Corrected gauges listing; It's Engine Temp, EGT, and oil pressure.
  10. Grayguy
    Grayguy Well-Known Member
    steering wheel price?
  11. MNRex07
    MNRex07 Well-Known Member
    Im interested in the ic tank just wondering if it would directly bolt into a 03 wrx
  12. Shancaldazar
    Worth a shot.... Steering rack and pinion?
  13. yuseforester
    Steering wheel is unavailable - noted in OP. Sorry!
  14. yuseforester
    Don't quote me, but I believe it will bolt into a WRX... anyone have one hooked up in their 02-03 chassis? Sorry, I don't actually drive a WRX or STi, so I'm not 100% sure.
  15. yuseforester
    That item is spoken for already too; I meant to list that as taken in the OP. Corrected.
  16. Mr.Tran
    Not sure either but when I looked into it. Didn't seem to difficult.
  17. kongzilla
    kongzilla Well-Known Member
    I take it that you kept the trans for yourself?
    We should work out a payment plan for those brembos :)
  18. yuseforester
    Yep, doing a full 6spd swap into the forester.
    If you are interested in the Brembos give me a shout; they would look boss on your XT!
  19. kongzilla
    Yeap interested in the brembo's but no real funds to fork up front.
  20. NastyLeggySS
    You have a pm.
  21. Dan7140
    Dan7140 Well-Known Member
    Is the left headlamp assembly intact?
  22. yuseforester
    Replied.
    All headlights were toast...:(
  23. yuseforester
    Added pictures. PM's replied.
    Defi gauges are updated for specs in OP.
  24. yuseforester
    Hood Scoop and splitter are pending sale.
  25. GreenGiant67
    GreenGiant67 Active Member
    Hey Yusef. Sent you a PM.
    Mark
  26. Moleness
    How toast? lol (Just curious if the passenger side is usable for making an intake thingy...)
  27. yuseforester
    I will snap a pic for you, but it's not intact as a hole unit.
    Replied!
  28. yuseforester
    Scoop and Splitter sold to NastyLeggySS - that will be a sweet mod on you Legacy!! Make sure you send a picture!!
  29. KA-T_240
    KA-T_240 Well-Known Member
    PS Pump going with engine?
  30. yuseforester
    It is staying with the steering rack, but I will let you know for sure. Thanks!
  31. yuseforester
    Got plenty of interest on things; but need to start making room for new projects! Bump it up. Will also be posting on Craigslist this week too...
  32. TheSnowman
    TheSnowman Well-Known Member
  33. Val
    Val New Member
    Do you have the rear tail lights, if so how much for them? Thanks
  34. tangledupinblu
    Quote and pic from above post(#1).:)
    "tail lights 140 ea $ 280.00"
  35. yuseforester
    Thanks Josh!
    Taillights are pending sale actually...if these fall through I will let you all know.
  36. yuseforester
    Tail lights are sold to TheSnowman! Thanks!! and your WRX sounds great!!
  37. yuseforester
    Price drop on Motor to $3,800.00!!
    twiztid_rs likes this.
  38. nate
    nate Well-Known Member
    Bump for a great price!
  39. shadysti
    shadysti Well-Known Member
    Lower control arms? Preferably just the drivers front,
  40. yuseforester
    Sorry, those are not available. :(
  41. yuseforester
    Exhaust is sold!
  42. yuseforester
    Full interior going up for sale shortly!!
  43. yuseforester
    MOTOR HAS BEEN PULLED! Now sitting nicely on an engine stand.
    You had your chance to see it run...
  44. derp
    Just calipers for 1k or is it carriers and rotors as well?
  45. yuseforester
    Unless I am mistaken Brembo's do not have carriers as they bolt directly to the spindles. IF you mean spindles, no, those are not included.
    Included with the Brembo's are the rotors (need to be turned to clean them up), the brake lines, and I have a used set of OEM pads I can send along too.
