2005 STI clutch engagement changing after car is warm
Discussion in 'Modifications And Maintenance' started by Babaganush, Apr 24, 2013.
  1. Babaganush
    Babaganush Active Member
    Hey Everyone,
    Im having an issue shifting my car into gear while stopped. This seems to happen when the car is warmed up and I can feel the engagement point of the clutch is closer to the floor when I do get it into gear. The car is a 2005 sti with 95xxx miles, act street clutch with stock flywheel. I have beed reading on nasioc about possible solutions but whenever someone figures out the problem the don't post the solution. Water in the lines? I don't see a external leak so is an internal leak possible?
    Any help is very much appreciated!!
    Babaganush
  2. BroCo
    BroCo Well-Known Member
    How many miles are on the clutch? Was there any recent maintenance done to the clutch?
  3. JasonoJordan
    Have you checked your fluid res or tried bleeding it yet.
  4. Babaganush
    The clutch was replaced this past october, has about 9k of normal driving on it.
  5. Babaganush
    I did bleed it, but fluid looks old. I should flush it but have never done it so I would like someone who knows what there doing to supervise.
  6. MNBD
    MNBD Member
    Did you follow the proper break-in procedure? Neglecting to break in your clutch disc is a good way to glaze your disc over.
    Was your flywheel resurfaced when the clutch was replaced?
