2006 STI Clutch Replacement - DIY or not?
Discussion in 'Modifications And Maintenance' started by TickTack, Dec 9, 2010.
  1. TickTack
    TickTack Well-Known Member
    For the sake of some cheap entertainment, here are smoe pictures of parts. Look about right/wrong?
    Stock flywheel (one of the heat spots penetrates the entire flywheel):
    Resurfaced flywheel:
    Stock pressure plate:
    ACT XT-SS pressure plate:
    Stock clutch disc:
    ACT Street clutch disc:
  2. TickTack
    Just thought I'd update this after a few thousand miles. The install went smoothly, even for a clutch swap virgin. The new clutch feels fantastic; it made me realize just how badly the stock unit was slipping before.
    Thanks for the encouragement, it was very rewarding to have done this myself.
  3. turbo_turtle
    Good to hear! Fuel economy return back to normal yet?
    ~Dan
  4. retreif
    My ACT kit was on my doorway when I got home and is now on the bench. Did you find one write up more helpful than others?
  5. TickTack
    Yup, right back to low/bad!
    Uhh, yup. This write-up and thread helped a lot.
    http://www.iwsti.com/forums/how-ins...-transmission-removal-driveway-method-gd.html
    I also bought a transmission jack from harbor freight (for $75 or so) and then returned it when I was done. It worked fantastically, I just didn't wanna store it. I'm not sure how I would've gotten it down low enough and with such precision without it.
    I notice a little bit of chatter in low RPM but I've decided it's my driving allowing the clutch to engage too quickly and bogging down. My daily beater is a '94 318is with a sloppy clutch, so I have a tough time jumping back and forth now.
