2007 Subaru Forester XT Partout
Discussion in 'For Sale : Group Buy/Bulk Lot/Part Outs' started by Kid_coupe, Mar 26, 2016.
  1. Kid_coupe
    Kid_coupe Member
    62,xxx miles
    Auto transmission
    Ej255 will be sold as parts not long block
    almost everything is pulled
    color code 48w
    Available
    $600 black leather heated seats/black leather rear seats
    $100 trailer hitch
    $60 pass airbag
    $50 steering wheel(no airbag)
    $200 pass front door (mirror is sold)
    $180 pass rear door
    $300 rear hatch full assembly
    $80 hood scoop
    $40 hood scoop splitter
    $140 oem cat back
    $100 drive shaft (auto)
    $200 rear differential
    $100 rear sub frame
    $100 front sub frame
    $200 steering rack
    $100 downpipe oem
    $50 downpipe
    $60 drivers taillight
    $60 pass taillight
    $750 auto transmission
    $40 rear bumper has dent in rear pass side can be pulled out with heat gun
    $50 center dash storage compartment
    $20 steering column trim (plastic under steering column)
    $80 roof cross bars pair
    $160 dash
    $50 black carpet
    $50 headliner with sunroof
    $30 drivers front window regulator
    $30 drivers rear window regulator
    $40 drivers rear window glass
    $40 each axel (4)
    $30 rear sway bar (end links cut)
    $400 strut/spring assembly set of (4)
    $60 radio
    $35 rear rubber cargo mat
    $20 e-brake handle
    $60 climate control bezel
    $30 cluster bezel
    $100 cluster 62,xxx miles
    $40 front sway bar
    $180 gas tank
    $50 drivers front knuckle
    $5o pass front knuckle
    $40 drivers front caliper
    $40 pass front caliper
    $50 center console cup holder trim
    $50 oem blow off valve
    $100 heater core
    $60 blower motor
    $30 dash beam
    $300 chassis wiring harness (uncut) front to rear
    $75 intercooler
    $40 wiper motor and linkage
    $120 downpipe
    $80 exhaust manifold
    $20 windshield wiper switch
    $20 turn signal switch
    $80 roof rails drivers and pass side
    $20 steering column bezel
    $60 steering column with key
    $60 drivers airbag
    $250 turbo
    $50 throttle body
    $50 oem turbo inlet
    $55 rear view mirror
    $20 security module
    $30 keyless entry module
    $50 drivers side skirt has crack by rear door
    $60 pass side skirt
    $20 spare tire
    $20 windshield washer reservoir
    $20 drivers front door actuator
    $20 drivers rear door actuator
    $10 radiator top support brackets (pair)
    $20 dome light
    $10 ECU cover
    $200 ECU (auto ej255 never been tuned)
    Sold-
    Grille
    front bumper
    hood
    Drivers fender
    Pass fender
    sunroof assembly
    privacy shade
    pass headlight
    rims/tires
    drivers front door shell
    drivers rear door shell
    pass side mirror
    radiator
    Ac condenser
    Ntxhuav_Khang and Ryan FailRad like this.
  2. Scott
    Scott Well-Known Member
    Too Bad for it being an auto. looking for the 5 speed. GLWS.
  3. Kid_coupe
    Kid_coupe Member
    I have 2 wrx transmissions 5spd interested? @Scott
    Ryan FailRad likes this.
  4. Scott
    pmed you
  5. scoob
    scoob Well-Known Member
    do you have the injectors available?
  6. Kid_coupe
    Kid_coupe Member
  7. Scott
    how much with the diff? 4.44 final drive right?
  8. Ryan FailRad
    No usdm wrx came with a 4.44, the ones he has available are probably 3.54
  9. runninlow
    runninlow Member
    pm me about the wrx transmissions very interested in 1 of them
  10. Kid_coupe
    Kid_coupe Member
    Injectors now sold
  11. accord917
    accord917 Well-Known Member
    Pm me about the front axel. I'm interested in both front passenger and driver. Also interested in the rear rubbet cargo mat. What color?
  12. immakhang
    immakhang Well-Known Member
    what kind of turbo?
  13. Ryan FailRad
    I'll respond for him since I'm helping him with it anyway, you pick a color for the cargo mat and we can get you one.
    I believe only one axle is good out of this car if that works..
    stock td04 turbo no shaft play whatsoever.
  14. mnnice
    mnnice Well-Known Member
    correct me if im wrong. i was under the impression that forester xts were 4.44 gearing. i believe it was 04-08 xts had 4.44 stock.
  15. Ryan FailRad
    You're more than likely right, but, read what I said again.
  16. mnnice
    haha my bad! that was one of those quick glance responses. i now realize he has 2 wrx 5 speed set ups. defiantly not 4.44 final drives!!
  17. Kid_coupe
    Kid_coupe Member
    BUMP! Willing to work out deals
  18. Kid_coupe
    Kid_coupe Member
    BUMP!!! I want this stuff sold!
  19. Kid_coupe
    Kid_coupe Member
  20. Sanjay raval
    Sanjay raval Member
    Any wiggle room on the rear sub frame? And would it fit right into an 07 2.5x foz?
  21. Tealsubie
    Tealsubie Member
    Is the transmission a 4eat or 5eat?
  22. b0yjeenyus
    b0yjeenyus Active Member
    PM incoming
  23. Kid_coupe
    Kid_coupe Member
    I believe it's a 4eat
  24. belalegosi
    belalegosi Well-Known Member
    correct
  25. Kid_coupe
    Kid_coupe Member
  26. Kid_coupe
    Kid_coupe Member
    BUMPPP!
  27. Kid_coupe
    Kid_coupe Member
  28. Kid_coupe
    Kid_coupe Member
  29. Kid_coupe
    Kid_coupe Member
  30. Dwight Ritenour
    Dwight Ritenour Member
  31. Kid_coupe
    Kid_coupe Member
  32. gfoz
    gfoz Member
    Interested in both doors. Passanger ones. And if you have the stock cato back.
  33. Kid_coupe
    Kid_coupe Member
  34. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    Heated seat switch Driver's side?
  35. predavore
    predavore Well-Known Member
    PM sent....
  36. predavore
    No response... do you still have this stuff available?
  37. b0yjeenyus
    Sent another PM
  38. Sanjay raval
    Sanjay raval Member
    Still got a drivers headlight? I need one, my current one has some headlight fluid (condensation)
