235's fit on my wagon with 52 offset?
Discussion in 'Modifications And Maintenance' started by hella_sti, Apr 16, 2008.
  1. hella_sti
    hella_sti Well-Known Member
    I've got a 2003 wrx wagon with prodrive PFF7 18 inch 52mm offset wheels. I'm currently running 225/40/18 dunlop sp 901 tires that suck. I want to run 235/40/18 kumho spt tires on my exisiting set-up. I'm lowered on prodrive springs and have -1.4 degrees of camber in the rear and -.5 up front.
    I currently have NO rubbing with my existing tires, My main concern is the clearence between the rear strut and tire. Right now I've got 4-6 mm of clearence between the tire's rim guard and the strut, the dunlops are a bit streched on the 8inch wide wheels so I'm thinking that a 235 would sit "flatter" and the rim protector wouldn't protrude as much.
    Any thoughts if these will fit or not??
  2. predavore
    predavore Well-Known Member
    10mm wider tire will result int 5mm rubber added to each side of that tire. If you have 5mm of space, you will not have any space later. I bought a set of 235/40/18 from someone who was going to put them on their wagon, but didn't fit.
  3. hella_sti
    what kind of wheel and tire setup did they have???
  4. predavore
    Not sure about the wheel, but the tires were Falken 615s.
  5. hella_sti
    those do run on the large side, though. 235's are more like 245's
  6. Dream
    235's will probably rub on a wagon, what's wrong with 225's?
  7. hella_sti
    they are too narrow for the 8 inch wide rims and the sidewalls are streched on my wheels.
  8. Rexwagon
    Rexwagon Well-Known Member
    you should have called me. i was just in minot today and already back to fargo. you could have tested my rt-615 225 on a 48 offset to see how close it would have been for u. Maybe it would have helped.
  9. hella_sti
    mine are 18 inch aren't yours 17's?
  10. Rexwagon
    yeah 17's
    but they are wide lol
  11. esperunit
    esperunit Well-Known Member
    problem is that wagons jsut really arent built for the 8 in wide wheels.
    bust out the fender roller because azenis/ecsta mx/dunlop ss/re070 runs really wide.
  12. hella_sti
    did anyone actually read my first post?! I'm looking at running 235/40/18 KUMHO spt's and my main concern is the clearence between the inside sidewall and the rear struts! I already have access to a fender roller so that isn't my issue/problem.
  13. hella_sti
    I looked at my buddies wagon today and he has the kumho spt tires and they don't have a rim protecting strip along the edge that will give me atleast a good, 5-6 mm extra room to play with.
  14. sjwelna
    sjwelna Well-Known Member
    You need to compare the sectional widths of the two exact tires that you both have right now and the one you plan on getting. Go to Tirerack.com and they usually have the specs listed for most of the tires on their site. If the sectional width isn't hardly any bigger then it might not rub, but if the sectional width is >1/2" from your current tire, then you will most likely rub.
    EDIT: Did some of the work for you:
    Kumho Ecsta SPT sectional width = 9.5" for a 235/40-18
    Dunlop SP Sport FM901's = ???? I can't seem to find specs on this size FM901 anywhere, are you sure it isn't a 215/40-18?
    I think they'll rub.
    -Steve
  15. hella_sti
    I'm postive that the dunlops are 225/40/18 I know tires better then the back of my hand. And tire rack lists the tire sizes on a universal chart, there is no descrenpancy between the different brands even if they are slightly different. So basically they go by each size and not the specific tire.
  16. Soupboy
    Soupboy Well-Known Member
    I'm running 215s fine on 7.5" rims...don't see the issue with 225s on 8" rims.
  17. Dream
    He want's to run 235's :eek:
  18. hella_sti
    I ordered them from discount tire on friday, wish me luck. This is my $500 experiment for all my subaru brothers out there!!
  19. silver03
    Couldn't you just add a 1/4" or 3/8" spacer?
  20. Mike Wagner
    Mike Wagner New Member
    Then he will have fender rub problems.
  21. Mike Wagner
    I have been running a set of 225s for the last 3 weeks with a 53 offset.
  22. hella_sti
    I got the tires mounted yesterday and they don't rub at all!! The rear fender lip comes realllyyyy close to the side wall under 80% compression but don't rub. They are nice and straight sidewalls and look to be the perfect size on the 18x8 wheels. They sure are sticky, too!! Everytime I drove thru a patch of sand or out of the groove in the road I could hear the tires flinging pebbles and crap up in the fenders, good thing I got my rally armor mud flaps! I'm probably going to roll the rear fender lips just to be safe if I'm carrying 100 lbs of groceries or something, hahah.
    edit: no strut issues either, they have the same if not better clearence then the 225's, they have a much better designed rim protector strip.
  23. Shibbs
    What tires are you running with? My Dunlop Z1 Star Specs throw sand and gravel EVERYWHERE. It is quite comical. I stuffed their ultra-wide 225s on my stock 7" wheels.
