25D DOHC Valve Lash
Discussion in 'Modifications And Maintenance' started by Threshld1, Apr 5, 2009.
  1. Threshld1
    Threshld1 Well-Known Member
    Anyone have the valve lash spec of a 97 phase 1 DOHC - shimmed buckets? My book only covers to 96 w/ HLA's.
  2. phi11
    Valve lash adjuster. ('97 2.5 DOHC)
    OD: 29.959 - 29.975 mm
  3. Threshld1
    How about lash between shim and cam w/ loeb (heh) 180* from face
  4. phi11
    Valve Lifter?
    OD: 32.959 - 32.975 mm
  5. Threshld1
    *Face-Palm* haha so close, clearance between bucket and cam with valve fully uncompressed - Valve lash. Should be in the .00XX" range
  6. phi11
    G2M0767
    3) Measure inner diameter of bush on cylinder head.
    Inner diameter:
    29.994 — 30.016 mm (1.1809 — 1.1817 in)
    CAUTION:
    If difference between outer diameter of valve lash
    adjuster and inner diameter of bush is over the limit,
    replace cylinder head.
    Standard:
    0.019 — 0.057 mm (0.0007 — 0.0022 in)
    Limit:
    0.100 mm (0.0039 in)
    or
    G2M0767
    3) Measure inner diameter of valve lifter mating part on
    cylinder head.
    Inner diameter:
    32.994 — 33.016 mm (1.2990 — 1.2998 in)
    CAUTION:
    If difference between outer diameter of valve lifter and
    inner diameter of valve lifter mating part is over the
    limit, replace cylinder head.
    Standard:
    Limit:
  7. subytek
    subytek Well-Known Member
    Does this help?
    .008" +/- .001" intake
    .010" +/- .001" exhaust
  8. Threshld1
    Perfect thank you both!!
  9. Threshld1
    Beautiful, all of them are <.0005" above spec within tolerance.
