93 octane and higher. where to find
Discussion in 'Off-Topic' started by Taras, Oct 9, 2007.
  1. Taras
    Taras BANNED
    Saint Paul, Minnesota
    what do you guys think about knocklite or knock link?
  2. Nuke
    Saint Paul
    I think you should stop buying stuff for your car for a while, until you get everything running good first...just don't toss stuff on it over and over, it'll be more difficult to narrow down your problem
    PLUS
    Gimme that money, I'll put it to good use
  3. Taras
    Taras BANNED
    well Knocklite think is pretty functional from what i have read about it and could help me with my problem. Does Enginuty tell the ignition retard?
  4. Taras
    Taras BANNED
    Another thing just came up to my mind wouldn't i have really high EGT's if i was running too lean to cause knock?
  5. WRX1
    Over there
    The reason it feels like you have more power down low, is because you probably lost 20+whp up top. Your afr's are out in left field (maybe even on the football field). You need to get it fixed asap or it will blow up. You have been told multiple times. Put the other map back on and run good gas, not that 91 crap. Then get someone to look at it that knows what is going on.
    No, it is something in the ecu that is doing it. This is a first allocation car, and they have been known to do some wierd things.
    Again, no. EGT has to do with timing more so than afr. This will be funny. What are you running for egt?? WOT top of the rpm band 3rd/4th gear. Nobody say anything until Taras posts up his egt.
    Oh ya, TIC TOC.
  6. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    Honestly, you tell change his current map because it'll blow (tic toc) then encourage a WOT run to make fun of him. What's the sense in that?
  7. Dream
    south
    I think he should just sell his car and buy a Civic.
  8. AWDimprezaL
    Monticello.
    i think he needs a 2.5 rs, somthing you can just run regular in, turn the key and go, some people shouldnt have turbo cars.
  9. Taras
    Taras BANNED
    Egts are below 1400 at wot most of the time on highway cruising its around 1200 or lower. The be honest i cant here any audible knock. The Iam is at 13 and does not bounce back and forth its is solid there. The top boost was at 16.85 psi read with a logger.
  10. WRX1
    Over there
    I was also answering his questions. He is also running 91 oct gas when he has been told multiple times that his tune was for 92 shell gas. I was also asking what his egt's are at a certain area, and since he really doesn't seem to care what he is running for gas with the current state of his car, he has probably already done the wot pulls. So I was looking for the info on what he was running at those times.
    Taras, where is the egt?? Those are kinda low (about 200 degrees), or ungodly high if it is celcius. But if the probe is in the uppipe or something like that the temps may be more inline with the location of the probe.
  11. Taras
    Taras BANNED
    Well, i run shell 92 now and will only run shell or BP gas from now on. The probe is in drivers side manifold on cylinder 3. And the gauge is maddad in Fahrenheit(sp).
