95 impreza awd auto tranny issues
Discussion in 'Modifications And Maintenance' started by errorcode3, Nov 7, 2009.
  1. errorcode3
    errorcode3 Member
    Hutchinson, MN
    so today was the first day i really got to drive my car (95 2.2l awd auto impreza)
    the issue, when i mash the gas it pulls like it should up to about 4000 rpms, then it nails what feels like a rev limiter. The car surges up a few rpms, then down, and the cel came on almost instantly (stays illuminated not flashing) i continued to drive it, just testing the car no smoke, no smell, and as long as i didn't rev it too high it seemed completely normal.
    the issue is kinda like some auto's do when its in park and you can only rev the motor to a certain rpm.
    and as far as the codes, i can't seem to find my reader for the life of me, and its late and gave up my search until tom.
    but until i can find the codes is there something i should be looking at?
  2. Shibbs
    May be a speed sensor in the transmission. I've seen an old ES do something similar to this.
  3. errorcode3
    errorcode3 Member
    Hutchinson, MN
    how hard is it to test/find/replace that?
    oh wait isn't that the plug/sensor on the top-left side of the tranny near the firewall (if your looking at the windshield)?
    could this be a symptom of my speedo not working?
  4. errorcode3
    errorcode3 Member
    Hutchinson, MN
    found the reader only code that popped up was- p0500
    Symptoms of a P0500 DTC may include:
    loss of anti-lock brakes
    the "anti-lock" or "brake" warning lamps on the dash may be lit
    the speedometer or odometer may not work properly (or at all)
    your vehicle's RPM limiter may be decreased
    the shifting of an automatic transmission may become erratic
    other symptoms may also be present
    sounds like i found my problem...
    now where do i get one?
  5. piddster
    Boostonia
    Get one what?
  6. prodriver1
    prodriver1 New Member
    Duluth
    i had the same thing happen to my 2.5 5spd leg outback. i brought it to the shop and they told me it was the cam speed sensor. only 4k rpm sux what a boring winter that was.
  7. errorcode3
    errorcode3 Member
    Hutchinson, MN
    the sensor, since napa, autozone, do not say they have them.
  8. errorcode3
    errorcode3 Member
    Hutchinson, MN
    it was the speed sensor, thanks shibbs.
    luckily the tranny i swapped in had a extra one that i pulled out and set aside and forgot about.
    and it sheared the little pin off inside the tranny so i had to use a needle nose to get it out. and that solved both issues (speedo not working and rev "limiter")
