97 LGT short shifter question
Discussion in 'Modifications And Maintenance' started by 6star97gt, May 7, 2008.
  1. 6star97gt
    6star97gt New Member
    Which short shifter is the best for the buck?
  2. Grayguy
    Grayguy Well-Known Member
    KartBoy.
  3. dman
    dman New Member
    I'd start with bushings, front and rear. Kartboy ones.
  4. phi11
    sounds like I need to order one of these.
  5. stoooo
    stoooo Well-Known Member
    Kartboy, but get the right one for your application.
  6. 9blackmax6
    dont mean to highjack but this thread seems pretty much over, will bushings make shifting smoother? my third gear is kinda messed up sometimes if i shift fast and i know the sink-roes help with it poping out of gear but do they help smoother shifting too? fyi my car doesnt pop out of gear its just a hard shift into 3rd sometimes
  7. stoooo
    You might benefit from fresh tranny fluid. Does Uncle Scotty's play nice in Legacy trannies ? I would think so since it's a 5MT.
  8. 9blackmax6
    idk where do you get it? checker or some ****?
  9. curly2k3
    talk to Grimmspeed, pretty sure they still have it all instock
  10. phi11
    yes we do have it in stock.
  11. EtchyLives
    EtchyLives Well-Known Member
    Yes. Yes it does. USC Fixed a lot of niggling issues in my tranny.
  12. dman
    dman New Member
    Bushings will eliminate the slop, and make shifts shorter. Smoothness - probably not.
    Hard shifts - like it goes in slowly or does not go at all until you try again in a different spot?
    If the latter - change the bushings and make sure you have a return spring down there, attached to a washer on top of front bushing.
    As for different mixes - when you help your synchros, you make life harder for front diff. I just run OEM or Redline NS
