A few engine rebuild/cleaning questions
Discussion in 'Modifications And Maintenance' started by petrakov08, Jan 22, 2010.
  1. petrakov08
    petrakov08 Well-Known Member
    I just got my ej25 out of the RS this weekend and I've been tearing it down to change the head gaskets. I'm also doing as much cleaning as I can before I put it all back together. The questions..
    Is there any way to refurbish the old nuts/bolts? Like a cleaning solution or something.
    Is there any problem with hot-tanking the manifold? Where do I go about getting it hot-tanked and what should I expect it to cost?
    I've been wire-brushing parts and it's getting them relatively clean but is there any cleaning solution or techniques I should be using to get parts cleaner?
    Can a motor run entirely on rust? because mine's apparently been doing so for years...
  2. Shibbs
    Sea-Foam works great for soaking parts.
  3. KA-T_240
    KA-T_240 Well-Known Member
    If you are trying to clean up old nuts and bolts and all that a wire wheel on a grinder works awesome. If they are damaged, just get new ones from a hardware store.
  4. petrakov08
    Yeah I'm going to replace all the ones I can but some are just weird sizes that I doubt I'll find
  5. Mr. Bill
    Mr. Bill New Member
    Fastenal is your friend for replacement bolts/nuts...Some of the stores have funky hours, but I've never had anything I can't find there.
  6. piddster
    If you have rusty nuts or bolts, muriatic acid does a great job of cleaning the rust off. It can be bought at most hardware stores.
    As far as important fasteners for an engine go, I'd buy new. For basic cleaning, a wire wheel on a drill works wonders. Cleaning carbon from parts can be done with carb cleaner or Seafoam.
  7. CBR04WRX
    CBR04WRX Well-Known Member
    Find a auto repair garage with a parts cleaner/hot tank. Bring in your parts and they'll throw it in the hot-tank. Remove all your electrical sensors from the intake manifold first. Prices vary, you should call them first.
    What do you mean by a motor running entirely on rust? EJ25 have an aluminum block/head/intake manifold.
  8. petrakov08
    Yeah I have the manifold all stripped and ready to go but the places I've called around me don't do hot-tanking, the search continues.
    Ha I realize they're all aluminum, it was a East Coast car so everything that can, be covered in rust, is.
