ABS Question
Discussion in 'Modifications And Maintenance' started by KSAL, Apr 6, 2014.
  1. KSAL
    KSAL Well-Known Member
    So I got one of the projects up and going today. (New transmission) and I took it out for its maiden voyage. (99 legacy 2.2 mt) I noticed when I come to the first stop sign the brakes didn't feel quite right... pedal wouldn't go in as usual. Kept going came to the next stop and i could feel it pulsing..... ABS was on even though it wasn't slippery or icy obviously. Totally dry pavement. So i drove it about 7-8 miles and coming up to a light the pedal went down like it was supposed to ABS wasn't kicking in, it was braking as it should.... but then the ABS light came on.?????
    Any ideas?
  2. JasonoJordan
    Fresh fluid?
  3. phi11
    damaged/broken ABS tone ring?
  4. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    I would guess tone rings. Each wheel has an abs sensor. I know there is a specific clearance between the ring and sensor. Maybe check the gap or clean them up and check wires?
  5. KSAL
    Thanks guys i will check all the sensors tonight or tomorrow!
  6. KSAL
