Acrylic Company *local*
Discussion in 'Off-Topic' started by Sogonerg, Nov 8, 2007.
  1. Sogonerg
    Sogonerg Anteater
    Anybody knows anyone that sells acrylic sheets (not in bulk) and also cut them to size?
    I'm planning to make a sump tank system for my aquarium...
  2. readymix
    I bought acrylic at Menards.
  3. phi11
  4. Sogonerg
    Sogonerg Anteater
    didn't know that...do u know if they cut them to size?
  5. Sogonerg
    Sogonerg Anteater
  6. phi11
    what thickness Acrylic are you looking for? 1/8"??
  7. Sogonerg
    Sogonerg Anteater
    Its gonna be filled with water...and about 48x18x18, I think 1/4 in thick would be safer...i think
    roughly 50-55 gals.
  8. phi11
    damn, like 416 pounds!
  9. phi11
  10. Sogonerg
    Sogonerg Anteater
    :biggrin:
    hope the 1/4 in. will hold haha
  11. Sogonerg
    Sogonerg Anteater
  12. phi11
    cause these are in my rolodex.
  13. Sogonerg
    Sogonerg Anteater
    Thanks phil...Talk'in to Classic right now...;)
    dam son...$200 rough estimate...
  14. phi11
    custom = $$$$$$$$
  15. Sogonerg
    Sogonerg Anteater
    not really custom...same price from another vendor in IL, but they produce them daily...that's there specialty I guess...different from ones that don't do this as an everyday thang...
  16. SubeN'Siren
    SubeN'Siren Well-Known Member
    How did you come up with 1/4"? I think I have seen tables for that somewhere while doing research for making acrylic vivariums and lids.
    If my memory serves me, 1/4" sounds kind of thin for the size of the tank.
    If you have access to a table saw, it is actually quite easy to cut the stuff to size.
  17. Sogonerg
    Sogonerg Anteater
    I was talking to a few vendors majority of them said 1/4 in. remember it isn't a full fledge fish tank...it is similiar to a wet/dry/SUmp system...probably about 50% of it will be filled with water, after all the filter media...
    I have no access to a table saw,I may just have them cut it to the size I need...Doesn't cost a whole lot more...Don't u need a special acrylic blade to cut it with so that you don't crack while cutting it?
  18. Shibbs
    55 gallon is a pretty shallow tank. Not that heavy at all.
  19. Sogonerg
    Sogonerg Anteater
    shibbs...better avatar...;) I was getting dizzy with the old one...lol
    if I really fill it (water), it is about 400+ lbs.
  20. Shibbs
    Sorry, I meant not that heavy for 1/4"
    Its not a very wide or deep tank, so I believe 1/4 would be fine. Although thicker on the bottom would never be a bad idea. More $$ tho.
  21. Sogonerg
    Sogonerg Anteater
    actually the bottom would matter as much as the front and back of the tank...the bottom has the floor to support it, so it won't bow out like the F & B
  22. phi11
    yes, this.
  23. SubeN'Siren
    No.
    I use a standard blade (can't remember the #) carbide tooth.
    You can get special blades for acrylic, but I've had good luck using mine, what I did was read the specs on the "special" blade, and found the closest one I could find at menard's.
  24. phi11
    whatever, we cut acrylic everyday,
    if the the specs are wrong, it will chip.
    I'm not saying go out and buy a diamond tip blade,
    you just have to know what your doing.
    not everyone has the RIGHT tools.
  25. Sogonerg
    Sogonerg Anteater
    Ghetto-fabulous!
  26. phi11
    yes, this.
  27. tangledupinblu
  28. Sogonerg
    Sogonerg Anteater
    I was thinking about that...Just thought I could go acrylic for not much more...lol
  29. tangledupinblu
    There you go "thinking" again.:roll::laugh:
    You know that you put us ALL in danger when you do that! lol
