alignment spec?
Discussion in 'Modifications And Maintenance' started by ruberdukwrx, May 1, 2008.
  1. ruberdukwrx
    ruberdukwrx Well-Known Member
    What are good aggressive but street able specs for a alignment?
  2. Shibbs
    I currently have my car set at -1.7 degrees all around, with 0 toe front and rear. Really normal tire wear. It can follow the grooves in the road a bit, but its barely noticeable. If you don't want that, you can add a little toe in, but that will greatly hamper the turn-in of the car.
    Side note - I wouldn't mind a little more camber on the front, but this is all I could squeeze out of the stock bolts.
  3. speedyham
    speedyham Well-Known Member
    -2/-1 camber F/R 0 toe all around. Somewhere around there is usually great for street use and not too hard on tires.
  4. Scuba Steve
    how often do you rotate your tires with that set-up?
    -2/-1 sounds like the perfect combo for hard and very fast cornering. :yumyum:
  5. Shibbs
    Despite what people say about camber, it is usually toe that kills tires. A little negative camber + toe out will really wear them alot faster on the inside.
  6. Scuba Steve
    i totally agree, toe /cross toe kills. But the last time I changed my camber i think i went too long without rotating and ended up frying the tires quicker than normal
  7. twofiveRS
    twofiveRS Well-Known Member
    Honestly I think camber gets a bad rap because people don't understand that the car needs to be re-aligned after camber is introduced or the car is lowered(which naturally introduces camber).
    Lowering without re aligning=massive toe in/out depending on where the rack is located.
  8. Shibbs
    Agreed. Especially on Honda Civics, drop = MAJOR camber and HUGE toe-out.
  9. Moleness
    I just got aligned...-1.75 in the front and -1 in the rear. Should be decent on the tires and it corners amazingly well :biggrin:
  10. speedyham
    I don't run that setup, it's just a good compromise between great cornering and good tire wear.
    I run -1.5F/-.8R LGT wagon with 0 toe for daily driving. On my Impreza I run -2.8F/-.9R with 1/8 toe out up front and 1/4 toe out in the rear. The Impreza can corner like nothing I have ever driven. :biggrin:
  11. Chin
    Chin Well-Known Member
    Well then, I may have to take it for a spin this year... ;)
