Amuse me.....
Discussion in 'Modifications And Maintenance' started by TRUBLU, Mar 15, 2007.
  1. TRUBLU
    TRUBLU New Member
    Dude....I was on my lunch break LOL...at home.
  2. Natural2JZ
    Natural2JZ Well-Known Member
    Well said..
  3. TRUBLU
    TRUBLU New Member
    LOL^^^^Tell me something I don't know. Now lets look at that equation. An EJ 2.5 running 4-5 psi is NOT going to be fast. So I will have reliable and cheap so STFU! LOL
  4. TRUBLU
    TRUBLU New Member
    Are you saying that if I'm just running 4-5psi then I just need the turbo, IC and custom exhaust made up to run this setup...that I may not even need to worry about the RRFPR? Injectors? Fuel Pump?
    I have my hands on a stock up pipe (thanks gran0393) which I'm going to use for the turbo flange on the end.
    AWDimprezaL do you think you could get me a clear list of what I need immediatly and what I will need to add to it in the future so I can actually have some serious fun?
  5. AWDimprezaL
    well each setup is different, immediatily you will need the turbo, intercooler, w/y pipe, you may also need a peice of radatior hose to get it to connect to the turbo, custom up pipe, custom down pipe, oil feed line, T fitting for oil feed, somewhere to tap for oil return (oil pan works) the RRFPR would be a good idea to have, idk how high the CR ratio is on a dohc
    2.5
  6. piddster
    I'd look for a coolant expansion tank.
    If you put your oil return on the pan, make shure its above the oil level, otherwise it can casue drainage problems.
    Good luck!
  7. TRUBLU
    TRUBLU New Member
    why would I need a coolant expansion tank and how different is it from a regular overflow bottle? Is the expansion tank held under pressure?
  8. AWDimprezaL
    because the turbo is above the rad cap, it will get a big air pocket in it.
  9. TRUBLU
    TRUBLU New Member
    ahh I see!...well that wouldn't be good now, would it? LOL
    Yes that last bit was a rhetorical question.
  10. TRUBLU
    TRUBLU New Member
    bypass valve acquired
    Have:
    turbo
    up-pipe to salvage the flanges off of
    down-pipe to salvage the flanges off of
    bypass valve
  11. AWDimprezaL
    look for a forester xt top mount, it will fit better then a wrx
  12. TRUBLU
    TRUBLU New Member
  13. AWDimprezaL
    i personally am using a weapon r, with gauge, it works really well
  14. TRUBLU
    TRUBLU New Member
    your thoughts on my injectors and fuel pump? Worthwhile upgrading or definetly needed upgrading?
  15. TRUBLU
    TRUBLU New Member
  16. AWDimprezaL
    That will work fantasticly
