Anyone in Burnsville want to help tonight?
Discussion in 'Modifications And Maintenance' started by Skarecrow, May 22, 2008.
  1. Skarecrow
    Skarecrow Well-Known Member
    Trying to slide off the stock manifold. All the hard hard stuff is done.
    But I could use a hand finishing, if anyone awake and near by.... Good karma?gas or beer?
  2. FAB KING
    FAB KING New Member
    Your a few hours late. Maybe in the AM..
  3. Skarecrow
    bloody stock heat shield. :(
  4. Scuba Steve
    you're talking the stock exhaust mani? that's a snap. Passenger side- Just wiggle it around and it will eventually drop out. I know the heat shield on top is a pain, but it will come out.
  5. Skarecrow
    I was trying to take the stock off on one piece, pulling the top heatshield off now, it was rubbing on the oil filter. I figure that was my issue. I'll know in a minute.
  6. WRXEcho
    WRXEcho Well-Known Member
    Yeah...loosen up the bolts that are attached to the driver side mani/crosspipe...that should make it easier to pull off. If you're putting the stocker back on, just loosely bolt the driver side mani to the crosspipe. That way it'll allow some play when putting it back on. And make your life a lot easier then trying to put it on with it all tightened up.
  7. Skarecrow
    Yea, taking off the stock, the heat shield was a fn pain in the ass.
    So now I'm thinking I need to take the cross, and driver side off and wriggle the rest.
    Good times.
  8. Scuba Steve
    what's the reason for such shenanigans on a thursday evening?:biggrin:
  9. Skarecrow
    LOL, I just got my headers and up pipe. And I hot itchy thinking the same thing when I got my inlet. "3 hours to myself and done"
    And I wanted a pretty sound for UNi tomorrow
  10. Skarecrow
    so if anyone still has some free time today, I could use a hand ;)
    give my cell a call
    952-250-2069
  11. Flat4
    Flat4 Well-Known Member
    im in burnsville all day
  12. xxtraloud
    xxtraloud New Member
    did you get it done?
  13. Skarecrow
    yes, and no....
    The headers / uppipe would have fit, had I been able to jack the engine a little bit to slide in the uppipe..
    however...
    the last minute decision after being under my car forever in a day, was to get it running so I could get to work tomorrow.
    so, I ran to grimspeed, got a new uppipe, and will be looking for a different set of headers ,especially since I didn't want to fiddle with a bunch of tuning tonight.
    so, all that work... and I'm sporting an up-pipe. which btw, is a very nice chunk of metal. however.. i think shes rattling on the subframe.... or the corner of the engine... because I hear a noise that sounds a bit like a wheel ball bearing is going out.
    was louder when I first started the car... but after test driving it a little to try and find out what it was coming from it quieted down to almost non existant... still there occasionally tho... and it might just take some time for everything to adjust..
    heres my deductions...
    under revs there is no noise,
    under high speed - with no gas there is no noise
    in a straight line high boost, there is no noise.
    it only seems to rattle when i'm turning and under gas.
    might just be a subaru making subaru noises tho... since I left ALL the shielding off.
    but hey, feel free to jump in with ideas :)
  14. xxtraloud
    :laugh::laugh::laugh::laugh:
    yeah that's a good conclusion. I am not sure what to say but you should double check all the bolts or maybe jack it and run it for a bit. maybe you've already done that.
  15. Ylime
    what uppie? I have a similar noise... cant figure out what it is or where is it actually coming from.
  16. Skarecrow
    its a grimspeed - found out it's the pipe rattling on the crossmember. I needed a fix to get to work and justin helped me out of a tight bind. it's getting taken care of tho which is more then appreciated.
