anyone need parts? from 00 turbo rs
Discussion in 'For Sale : Car Parts' started by meejoluj, Apr 7, 2005.
  1. masube81
    masube81 Well-Known Member
    Tommy check on the first page. Meng number.:D
  2. tbone
    tbone Well-Known Member
    Ups sorry I was lazy to click first page!!!
  3. Impreziv
    Impreziv Well-Known Member
    curious on struts and springs and sway bar with end links, are they still available, and if so how many miles on the struts and spings- Matt
  4. meejoluj
    meejoluj New Member
    spring and struts and wsay bar& links are gone
  5. Dynapar
    is the drivers seat in good shape? my dads car needs one. his ot squashed by previous owner.(feels wierd to sit in)
  6. meejoluj
    meejoluj New Member
    it is ripped in the front and is dirty from the crash but other than that it is still intact.
  7. Dynapar
    how bad is the rip? is it noticeble and or repairable? and how much?
  8. meejoluj
    meejoluj New Member
    you could probably repair it if you know how to work with vinyl. $50
  9. esperunit
    esperunit Well-Known Member
    I am VERY intersted in the turbo kit for a project car. Please email me at [email protected] so we can discuss a few details, but otherwise, I'm 75% sure i'll buy it.
    -zak
  10. prezawagon
    prezawagon Well-Known Member
    If they're not broken, I'll buy the front corner lenses. $40 for the set if they're both good, or $20 for the passenger side only?
    I see someone else called the sun visors. But if he doesn't want them, I'll be second in line for both of them if they're in good shape. $40 for the set?
    Also, the center armrest, whether or not it's the extended type. $20 non-extended, $40 extended?
    Thanks,
    Joel
  11. TheWRX
    TheWRX Well-Known Member
    Hey meng do us all a favor and post up EXACTALY what is left. Personally I want ot know if the rotors are still avaliable...
    Mohd
  12. Deride
    Manual transmission? still got the rear end? I couse use the limited slip.
  13. Deride
    Nevermind, just read the rest. I snooze I lose.
  14. FuJi K
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Deride
    yea, it's in my car right now.... :p
  15. meejoluj
    meejoluj New Member
    what i have let is the motor no injectors with act clutch 90XXX miles, rear brembo Cross drilled and sloted drotors and calipers(f&r) and pads, sti tranny mount, all axles, driver seat, cusco lower arm bar, front bumber beam, front clear turn signals, corners, driver side doors, alternator, stater, cluster, and the turbo kit
  16. wrxchic
    wrxchic New Member
    how much for the rear rotors?
  17. LilRed
    LilRed Well-Known Member
    you still have to rear rotor?
  18. Dynapar
    how much for the front bumper beam?
  19. meejoluj
    meejoluj New Member
    i still have the rear rotors $50 the bumber beam is for yia.
  20. meejoluj
    meejoluj New Member
    My buyer for the turbo kit dropped out on me, so if anyone wants the AVO kit with the full exhuast system i'll sell it to them for $2000, i want to get rid of it to make room in my garage.
  21. meejoluj
    meejoluj New Member
    i'll also give you a hks blow-off valve and boost & a'f ratio guages in the pillar pod
  22. LilRed
    50? hmmmm... i gotta see how much money is in the bank first. i'll get back to you on that one
  23. LilRed
    how hard would it be to put the avo kit on?
  24. meejoluj
    meejoluj New Member
    it took me and my friends half a day. its actually easier then other kits i've put on.
  25. LilRed
    do you think you'll head to midway tonight? i probably be there. if you are there i would like to see the rotors and possibly take them off of your hands
  26. Dynapar
    does AF gauge coem with wideband O2 sensor?
  27. meejoluj
    meejoluj New Member
    its just a autmeter a/f ratio gauge w/ no sensor
  28. meejoluj
    meejoluj New Member
    i still have some stuff for sale
    cusco lower arm bar $20
    sti tranny mount $20
    front bumber beam $50
    cluster $20
    distributor $20
    used act clutch and pressure plate 20K $25
    starter$30
    alternator$30
    wiper motor$20
    some other stuff...
  29. LilRed
    what other stuff? like brakes rotor?
  30. TheWRX
    If it's not asking for too much can u name the some other stuff. Also do u know if that cluster would fit on my car 93 impreza L AT
  31. TheWRX
  32. AWDimprezaL
    i can already tell you mo...it wont its electric speedo, we have cable :oops:
  33. meejoluj
    meejoluj New Member
    other stuff
    i have brake booster & master cylinder $40
    clutch slave cylinder and line $40
    both passenger doors (red) with windows and window switches
    ABS controller $50
  34. wagonL
    wagonL Well-Known Member
    since i need the clutch, i will probably buy yours...is it still for sale?...well...let me know...
    wagonL
