Are rt-615s a directional tire?
Discussion in 'Modifications And Maintenance' started by pbedroske, Apr 15, 2008.
  1. pbedroske
    pbedroske Well-Known Member
    Madisonville, TN (Tail of the Dragon)
    Ok, I put on my rt-615s last night, and maybe I was tired, but what direction are they supposed to rotate? I could not find an arrow indicating rotational direction, only the "outside" mark on the tire, that's kind of obvious on the rim. Seems to me I have 4 tires with tread in the same direction. Are they a directional tire or not?
  2. predavore
    predavore Well-Known Member
    Southern 'Burbs
    They are more like bi-directional.
  3. Soupboy
    Soupboy Well-Known Member
    St. Louis Park, MN
    They like to go forward. The traction in reverse is awful.
  4. pbedroske
    Does this mean it doesn't matter what side of the car they go on? They can rotate in reverse relative to the side they were on? If they were on the drivers side last fall, and now are on the passengers side they would be rotating in reverse.
  5. Paul Revere
    In the land of ice and snow.
    They have an inside and outside as long as the outside is on the outside (which they all should be) your good to go.
  6. Bullwinkle
    Saint Paul
    No, they're not directional. You'll be fine.
  7. TSTRBOY2004
    this is correct... its a semi-directional... ;)
  8. Chin
    Chin Well-Known Member
    Savage
    Asymmetrical, but not directional. ;)
  9. Shibbs
    Bingo. I was starting to lose faith in people's knowledge. :laugh:
