Awful gas mileage all of a sudden.
Discussion in 'Modifications And Maintenance' started by issues, Oct 18, 2012.
  1. issues
    issues Well-Known Member
    Car: 03 wrx 5 spd
    Pertinent Modifications: bullwinkle stage 2 (85k miles) invidia catless tbe, vishnu catless up pipe.
    Description of the problem: I've been getting gas at either BP on robbert or costco. I've been getting 25 avg in the winter or summer. About 2 tanks ago I noticed I was getting at best 20 avg. I've been noticing a lot of back firing lately.
    Recent maintenance or modifications: I have replaced my air filter plugs(1 stage colder NGK) and did an oil change( rotella t6 5-40 ) same oil i've been using for the last 150k.
    When I did my plugs they looked like 30k plugs no oil, not running rich, not running lean.I was thinking it could be my injectors leaking a bit. Also after I did my plugs my idle vac was dead on 18 inhg before it was bouncing between 18-20.
    Thoughts?
  2. readymix
    Did you get tuned for said colder plugs? Colder plugs are going to change some of the dynamics of the ignition cycle. My guess is, your spark timing was set for hotter plugs, and was burning the amount of fuel you were tuned for properly, and when you went colder, your spark timing doesn't jive with the new plugs and you aren't burning all the fuel.
    My suggestion, get retuned or go back to the plugs you were using before.
  3. issues
    I was getting the bad milage before the new plugs.
  4. readymix
    Yeah, check your injectors. Also, if everything checks out, I'd suggest maybe getting a re-tune.
  5. issues
    well im glad I have an extra set of injectors.
  6. svxninja
    svxninja Well-Known Member
    reflash?
  7. idget
    boost leak test?
  8. issues
    nuke sugested a reset of the ecu so thats what ill be trying first. the car boosts and holds boost fine.
  9. GiMp
    GiMp Well-Known Member
    But your name is issues
  10. issues
    yes but not when it comes to my car
  11. bikerboy
    bikerboy Subie GOD
    What is your STFT?
  12. issues
    stft?
  13. Nuke
    Short term fuel trim
  14. issues
    i have no idea
  15. scrubaru
    scrubaru Member
    Is this hwy mileage cause I'm getting around 18 in town with my 04 sti
  16. issues
    per tank avg
