? b4 I install H-Brace
Discussion in 'Modifications And Maintenance' started by ej20, Apr 14, 2008.
  1. ej20
    ej20 Well-Known Member
    Just curious, is it ok to take off these bolts/screw? I mean will anything fall/slip out of align if I took it off too install the H-brace?
  2. blackozone
    No. Take those bolts out and throw it in.
  3. Jackstand
    Jackstand Well-Known Member
    I forgot i had one of these i suppose ill put it in today
  4. EtchyLives
    EtchyLives Well-Known Member
    Those are the subframe bolts. IIRC there are about 9 bolts holding the subframe onto the car. You're not going to lose anything. The other bolts are for the rear bushings on the front control arms. They're not going anywhere, either.
  5. Rexwagon
    Rexwagon Well-Known Member
    you will be fine
  6. Bullwinkle
    Yup, Greg's got it. Had to take mine off to do the front sway bar. It's got a ton of bolts.
  7. ej20
    Thanks all.
