Blinker issue. Help?
Discussion in 'Modifications And Maintenance' started by babiker712, Apr 20, 2011.
  1. babiker712
    babiker712 Well-Known Member
    I have a 2000 Legacy Gt. In the last week, I've started having issues with the blinkers. This is only when I am making a left turn, and it is very infrequent. about 1 in 20 left turns I will have no blinker light outside or on the dash and the blinker sound goes into double time. This is consistent with what I have experienced in the past with other burned out headlight bulbs, only it was an all or non principle.
    Now, if this happens, I can (and without changing the position of the steering wheel) cancel the turn signal and reengage it, and have it operate perfectly. I looked at the bulbs and they seem fine. Is this a flasher or switch issue, and how do i fix it?
  2. sneefy
    sneefy Well-Known Member
    Double-time sounds usually mean a bulb out. Otherwise, if you've replaced the bulbs (i assume you tried that first, yes?) a bad relay perhaps?
  3. babiker712
    I haven't replaced them, but I pulled them out and looked at them and they appear to be good. The double time I've experienced in the past was a bulb issue, but it was an all or none deal, not intermittent as it currently is...
  4. predavore
    predavore Well-Known Member
    Low on blinker fluid?
    Now seriously, might be a bad bulb, could be a relay. Could be the whole turn signal assembly. Loose wire?
  5. Threshld1
    Threshld1 Well-Known Member
    I would say its the contacts in the stalk arm wearing out.
  6. babiker712
    "I would say its the contacts in the stalk arm wearing out. "
    I'm thinking this may be it. How could I confirm this?
  7. Little GS
    Little GS Member
    had this same problem! took the light out and it looked fine. even tested it and nothing seemed wrong but once i changed the bulb it fixed the problem.
  8. babiker712
    Wasn't the rear. I'm going to order some amber bulbs and use the front replacement as an opportunity to "clear" the headlights.
  9. babiker712
    +1 internets for you sir. I took it apart and sanded the points, seems to have improved significantly, enough that I'll probably wait to find one at a junker rather than getting a new one.
