blue a tip?
Discussion in 'Modifications And Maintenance' started by Clu7ch, Oct 15, 2008.
  1. Clu7ch
    Clu7ch New Member
    Anyone know how to blue an exhaust tip? i know its sum type of torch well at least i would assume but any insight?
  2. AWDimprezaL
    a torch with a non cutting type flame, slow even application of heat, and some kind of a metal polish.
  3. carl
    cut off blood flow
  4. sneefy
    sneefy Well-Known Member
    Paint the tip with ground rice.
  5. fondune
    GROSS.
  6. bobafett04wrx
    bobafett04wrx New Member
    OWWW!!! NO!
  7. putz
    putz Well-Known Member
    Blue LEDs???
  8. gc8
    gc8 Well-Known Member
    Rubber Band
    :run:
  9. piddster
    What 3ric said. And if you screw it up, you can sand it off and try again.
  10. phi11
    Don't burn yourself...
  11. readymix
    !POST OF THE DAY!
  12. Clu7ch
    Clu7ch New Member
    haha that was quick... lol i was wonderin if a propane torch would be easier to do it with? but its not a special gas?
  13. AWDimprezaL
    a propane torch may not get it hot enough, but then again, it just might be the perfect amount of heat.
  14. sjwelna
    sjwelna Well-Known Member
    Don't get it too hot, once the color has pushed past the temper color you are desiring, you have to bring it back all the way up to working temp and cool it off again (read: orange heat). Use a MAPP gas or propane torch with slow, gradual, even heating of the metal. Give it a few passes with the torch and take it away, rinse and repeat until you see ANY color start to show. Once the color you are looking for is showing QUENCH IT IMMEDIATELY! If you let the colors draw in any further you can overshoot. You can always work your way up the color chart (in terms of getting hotter) but once you go past a color temp, you can't go back down without a full reheat/cool cycle.
    -Steve
  15. Shibbs
    Would running an extra injector in the muffler and dumping alot of fuel thru the system get the same results?
  16. piddster
    Not that he'll be able to know what temperature the material is at when he does it, but just want to point out that this scale is for essentially mild steel. Varieties of stainless will be much different in their reactions to temperature.
    Good advice none the less.
  17. Speedemon
    Speedemon Well-Known Member
    map gas torch
  18. TSTRBOY2004
    called a infrared thermometer ;)
