Bolt Extractors
Discussion in 'Modifications And Maintenance' started by Paul Revere, Oct 8, 2008.
  1. Paul Revere
    So one of the last times I did my oil change upon taking off the skid plate I broke of three bolt heads. Not a big deal and I didn't think anything of it. But today I went to drill and extract them and I have already gotten an extractor broken off in one of the holes. Does anyone have any advice and or could help me later? I have b33r, V8 juice, and Sunny D your welcome to all of them and you can even mix them if you would like :yumyum:. I would like not to break any more extractors since I am borrowing them and I don't think they are cheap.
    Thanks
    Chet
  2. manochromatic
    manochromatic Member
    why dont you just drill them out?
  3. Paul Revere
    Then clean the threads?
  4. Scuba Steve
    so this is what happens when you work on your car without adult supervision?
    I kid...
    GL Chet- go drill them out
  5. Paul Revere
    You were there when I snapped them off.
    *awaits Fondune to change my words*
  6. Paul Revere
    I don't have anything to chase the threads. :(
  7. Scuba Steve
    i don't recall said event..cause I would've given you loads of crap...and I usually remember that
  8. Paul Revere
    You were doing my brakes, thats why I left the skid plate at your place.
    Off topic question did you get different bolts for your metal skid plate?
  9. Vector
    Vector Rally Organizer
    Go to northern tool. Buy set of reverse (left hand) drill bits.
    Drill out going from a smaller size to a larger. Usually the bolts will simply back out before you get big enough to use an extractor.
  10. Paul Revere
    Also I think I could get them out if my drill would grip the bit when in reverse.
  11. Scuba Steve
    yes...and Vector was the brains behind that skid plate operation
  12. Vector
    I can answer that. Yes, I sold the skidplates with new bolts, so he wouldn't havbeen reusing the stock ones (probably)
  13. Scuba Steve
    and since I have a new underbrace from fobia that skidplate bolts right up and sits super flush....again, a big kudos to you mark. Thanks for the quality workmanship
  14. putz
    putz Well-Known Member
    well......;) think about
  15. Paul Revere
    Ok well this is frustrating can someone just come over later and help? Thats what the point of this is.
  16. legendx
    legendx Well-Known Member
    yea its best to drill them out and re-thread all the holes.
  17. Paul Revere
    I guess I'll put it back up on the stands it ain't like I got anything else to do.
  18. putz
    thats it! and have a beer or 2 on yourself, you deserve it!
  19. wrxin
    wrxin Well-Known Member
    try using a easy-out?
  20. Paul Revere
    Update, I got 2 of the three out, the one that remains has an extractor stuck in it. I'm not dumb enough to drill into hardened steel. The two that came out I had to sacrifice the threads but thats no biggie, I'm gonna make them larger this weekend.
  21. TSTRBOY2004
    have you EVER tried to drill out extractors??? pretty much impossible.. tried on a door hinge...
    you may need to do some drastic things and then re-tap for a bigger bolt
