boost gauge?
Discussion in 'Modifications And Maintenance' started by bobafett04wrx, Oct 20, 2008.
  1. bobafett04wrx
    bobafett04wrx New Member
    so I just hooked up my autometer boost gauge, and it reads in hgs and psi. It was only in hgs and didn't go into psi. Did I set it up wrong or is this normal. I put a t fitting on the hose to the gauge and used a piece of hose to go on the bpv and put the hose that runs to bpv on the other side of t fitting.
  2. Kevin
    Kevin Well-Known Member
    were you driving it or just revving it up?
  3. bobafett04wrx
    just reving in the garage
  4. Bielke55
    Its very hard to get into PSI just revving... Try driving
  5. bobafett04wrx
    ok I'll drive it around, I'm new to boost gauges so I'm not sure whats sapose to read like.
  6. gc8
    gc8 Well-Known Member
    hahaha, ya drive it and you'll have fixed your problem!
  7. bobafett04wrx
    yeah after a drive it seems be working fine, I boost'd to about 14psi. So I'm preatty sure its hooked up right.
  8. strangefamous
    now you just need to work on getting above 14 psi :biggrin:
  9. bobafett04wrx
    Word! Yah thats gonna be the next step, I just need to get a dp and get my gmbcs hooked up, then I can get a tune done!
  10. strangefamous
    do you have an 04?
  11. bobafett04wrx
    04 wrx
  12. strangefamous
    ok nevermind then. I was going to see if you wanted an uppipe.
  13. driftin240
    driftin240 Well-Known Member
    He may still want one. He has a WRX, which means it still has a cat in it.
  14. bobafett04wrx
    yeah it still has stock up pipe. I want dp before I do up pipe.
  15. driftin240
    But you don't want to go stage 2 on a catted up pipe. I've seen failures of the cats, and your turbo WILL NOT thank you...:eek4:
  16. bobafett04wrx
    yeah thats true, maybe I should look into that.
  17. Shibbs
    Way to go scaring him into buying from you!! :p
  18. driftin240
    I don't have one for sale...
  19. Sky58
    Sky58 Well-Known Member
    Take it from the guys and if you get a DP, then get a non-catted UP as well. Might as well do it in all one swoop while you're working on the car :)
  20. Ej22TIM
    Ej22TIM Well-Known Member
    ive got an uppipe you can have for 40.00 its catless and never used.
  21. bobafett04wrx
    tell me more about it, or just pm me, it will fit on a 04 wrx?
  22. Ej22TIM
    yes it will, I got it in a package of ebay headers with up pipe, I got an invidia one instead.
    I can get some pics of it if you want, dont be scared about the ebay aspect of this up pipe. ebay is where the best exhaust deals are at yo!
  23. bobafett04wrx
    yeah some pics would be good, how much was your invidia up pipe?
  24. Paul Revere
    Crucial up pipes FTW!
