Hey anyone out there have a tester that i can use quick.? It would be much easier to borrow one rather then have to make one pain in the ass btw 20g 8cm housing if that at all makes a diff
Turbo size shouldn't matter since you should test from the inlet....unless you know leak is post turbo
I made mine pretty easy with some pcv and a brass fitting. Just have to make sure to plug off the hoses that shouldn't ever see boost if you want to put it on the intake. .
