Boost Surge???
Discussion in 'Modifications And Maintenance' started by joe bretto, Oct 26, 2012.
  1. joe bretto
    joe bretto Member
    hello tonight while driving home i noticed while in 4th and 5th gear it surges in and out during full boost i am no expert on these things. anyone have any ideas thanks.
  2. mnnice
    mnnice Well-Known Member
    mods? and when you say boost surge are you saying it spiked? or jumped from target boost to above target boost? gotta expand on the details to get a good anwser
  3. Talonted
    Talonted Well-Known Member
    i think he means compressor surge, probably because its getting cold out
    Buddy likes this.
  4. xluben
    Are you going well over 100MPH when this happens? If not, you're probably over boosting because you're going WOT at low RPM. You should downshift to a lower gear before flooring it.
    Talonted likes this.
  5. Talonted
    get a boost gauge
  6. joe bretto
    joe bretto Member
    2004 wrx downpipe and exhaust. Tuned at rs motors. I did 4th all the way it's weird it boosts then cuts then boosts again.
  7. Talonted
    most likely boost cut, its because its cold out i would get the tune checked to be safe
  8. joe bretto
    joe bretto Member
    Damn I just got it tuned. You rec taking it back?
  9. Talonted
    im not saying re tune it, just have it looked at and checked over
  10. joe bretto
    joe bretto Member
    Anyone want to take a look at it? I'm free this weekend
  11. Ronnie@RSmotors
    You are hitting boost higher than the target (what its tuned at). When that happens the wastegate will close until the boost drops below the target. This can go in a cycle. If its doing it all the time, I can adjust the comp table to drop duty during colder intake air temp.
  12. Ronnie@RSmotors
    Are you still on that same whiny turbo? Maybe it decided to spool better and create more boost this time. Has it been doing this since the tune?
  13. Talonted
  14. joe bretto
    joe bretto Member
    Ya been doing since. And ya still the same turbo. When could you look at that?
  15. Ronnie@RSmotors
    Never heard from you after the tune. I could've fixed it that same day. Bring it over.
  16. joe bretto
    joe bretto Member
    Ok sounds good your not there tomorrow are you ?
  17. Ronnie@RSmotors
  18. joe bretto
    joe bretto Member
    Ok sounds good have a good time I Gould swing by at?
  19. joe bretto
    joe bretto Member
    And that whinny turbo I can only hear that when its cold out.
