BOV or MBC???
Discussion in 'Modifications And Maintenance' started by MPLSREX, Mar 8, 2013.
  1. MPLSREX
    MPLSREX Well-Known Member
    Trying to get some opinions.
    Which mod would you recommend?
    A blow off valve like Go Fast Bits TMS Respons Hybrid Blow Off Valve, or
    a Grimmspeed manual boost controller.
    Thanks
    FuJi K likes this.
  2. JasonoJordan
    Honestly...neither.
  3. Shane86
    Shane86 Well-Known Member
  4. Moleness
    I have both.
    ofspunk7 likes this.
  5. Nuke
    You are awesome
    Thats why
  6. WRX1
    Next question to the OP, why do you think you need them??
  7. MPLSREX
    I don't NEED them, but I would LIKE to have my turbo spool up quicker and not have so much lag
  8. Moleness
    A blow off valve will not do anything for spool up. As for the other part, it may a little, possibly paired with an EWG. A good person to talk with about it would be your tuner.
    What is your current setup?
  9. ofspunk7
    Another vote for talking to your tuner.
  10. MPLSREX
    Just the SPT catback and a mild Nuke tune
  11. Mr.Tran
    Mr.Tran Well-Known Member
    Down pipe will yield the results your looking for.
  12. MPLSREX
    This is the description of what the BOV I was looking at does.
    As the name suggests, the GFB Respons is designed specifically with the aim of improving throttle response and reducing turbo lag.
    What’s TMS? GFB’s Turbo Management System is the term they apply to their diverter valves that have features designed specifically for the purpose of turbo lag reduction.
    Tests show that TMS features can return the engine to peak boost up to 30% faster than a factory diverter valve when shifting gears.
    On top of the TMS benefits, the Respons also packs GFB’s patented adjustable venting bias system found on the Stealth FX.
    This unique system allows the amount of air vented to either recirc or atmosphere to be infinitely varied to change the venting sound like a stereo volume dial.
    So if you want noise with your performance, the Respons can deliver. By fine-tuning the venting ratio, you CAN achieve a blow-off sound WITHOUT throwing a CEL, running rich, stalling, using more fuel or causing any other problems commonly associated with atmo-venting valves on cars with MAF sensors.
  13. Bullwinkle
    This is bull****. Don't buy any of these parts. If you want better performance, get a custom tune.
    Here, try this.
    ofspunk7 and Moleness like this.
  14. MPLSREX
    Thx for the the info guys.
