Bov ??
Discussion in 'Modifications And Maintenance' started by TheSnowman, Sep 18, 2009.
  1. TheSnowman
    TheSnowman Well-Known Member
    Is anybody on here using a TurboXS Type H-RFL BOV? Ive read they cause your car to stall in slow moving traffic or in reverse. i was just wondering if that was true of if people are happy with this BOV.
  2. Deride
    Don't use a bov on a Subaru with a mass air flow sensor. Use the search button this has been discussed many times.
  3. Shibbs
    If they're not adjusted correctly, they can cause many problems.
  4. john
    john Well-Known Member
    If you need to replace your OEM part with an aftermarket part, recirculate it.
    I vent mine to atmosphere, but I have converted to a blow through MAF which sits in the IC plumbing just before the throttle body.
  5. Snowbum
    Snowbum Well-Known Member
    ^wow, thats actually a really good idea!
  6. readymix
    As have I. I'm running the RFL.
  7. readymix
    Also, I might add, the reason people stall is because they don't adjust it. You have to stack the shims inside it till it idles and pops properly. If you just slap it on your car without adjusting it first, it will probably cause issues.
  8. TheSnowman
    alright all good info thanks, sorry for the noob post
  9. Aegis
    It's not a n00b post if it's truly something that you're worried about. Everyone has to ask questions sometimes :) I think I speak for all of us when I say I'd rather see you posting what you think is a dumb question, than blowing up your car because you didn't know.
  10. TheSnowman
    yeah i was just trying to figure out if it was a good idea to get one or not...and it looks like im not gonna get one ill stick with what i got.
  11. KA-T_240
    KA-T_240 Well-Known Member
    I have a open Vent Greddy RS on my 240 and love it! I have problems with the car stalling/flooding every once and a while. But the tune might have something to do with it. My buddy has a open vent greddy on his wrx and has never had a problem with it.
  12. Shibbs
    I've been running a full atmo BOV on my 07 for all but 2 months of its life. Still working fine. No stalling, no flooding, no problems. Of course, mine is adjusted properly.
  13. TheSnowman
    alright so it sounds like as long as the install is right it will work right
  14. Glock_Turbo
    Glock_Turbo Well-Known Member
    waiting on my turboxs hybrid, will let you know if that is a better option. or else upgrade to perrin recirc.
  15. TheSnowman
    i have a recirc right now, i was just debating whether or not to get a bov.
  16. tank1987
    tank1987 Well-Known Member
    adjusting
    Was curious how do I adjust my turbo xs bov, I put it on one day and took it off the next it made my car run like garbage.
  17. Shibbs
    Threadjack. :rolleyes:
    But, there should be instructions online. Usually has to do with tightening a screw, possibly stacking washers/quarters inside the unit to tighten the spring.
  18. TheSnowman
    ive heard of the stacking washers way of adjusting them
  19. tank1987
    Gotchya, Ill have to check them out online, I never got instructions with mine. Subaru 003 I see you have what looks to be a front mount, did you stay with a stock bov? Or upgrade it?
  20. TheSnowman
