Brake upgrades
Discussion in 'Modifications And Maintenance' started by Paul Revere, Jul 6, 2008.
  1. Paul Revere
    So Mike Wagner talked me into getting a sweet set of pads and rotors, now what do I buy? I bought Taras' rear slotted rotors he had for sale and now I'm looking at front rotors, pads and SS brake lines. I am thinking about EBC Green pads, Hawk HPS, .... Mike said NAPA has some good pads (not saying your wrong Mike ;)). What do some of you guys run and how do you like them.
    Oh as for the driving it will be mainly street with an occasional trip to the track or an auto-x event.
  2. idget
    I'd suggest a mild pad (hawk hps, carbotech bobcat, etc), some cryo'd front rotors, stainless and coated lines (goodridge), good fluid, and I'd throw in a brake master cylinder brace too (~$80).
    I have carbotech bobcats on the civic and ran hawk hps on the wrx... on the street they are pretty similar. Haven't pushed the civic, and I can't speak to dusting (dark wheels on the wrx and the civic is beyond trying to clean it up)... what tires are you running?
  3. Kevin
    Kevin Well-Known Member
    i have Hawk HPS pads and powerslot rotors and love the setup!
  4. Nuke
    If you're looking at EBC, go with the Redstuff.
  5. Paul Revere
    I am currently running rt615's. I want mild pads cause I drive the car all year dont cha know.
  6. Paul Revere
    Other than Perrin who makes a master cylinder brace?
  7. idget
    Cusco and carbing has one that integrates into their front strut bar. I'd recommend the cusco.
  8. readymix
    A little OT here, but idget and chet's avatars are similar so for a moment there I thought idget was talking to himself.
  9. idget
    lmao... sometimes I feel like I'm talking to myself on here :(
  10. Nuke
    :laugh::laugh::laugh:
    Speedyham's avatar and yours looks the same also.
  11. idget
    wat? :laugh:
  12. mnstilynwrx
    mnstilynwrx Well-Known Member
    ^^ :laugh::laugh: wate whos talking here?....
  13. Paul Revere
    Alright you two back on topic ...
  14. Justin
    Justin Well-Known Member
    i have some barely used hawk hps pads for all 4 corners, front cryo'd powerslots also barely used, and rear h6 upgrade barely used all for sale. havent posted it yet but if you are interested hit me up on pm.
    Justin
  15. Mike Wagner
    Mike Wagner New Member
    Nice I know where this has come from.
  16. Paul Revere
    Thanks for the offer Justin but I have a slight issue with used brake products, call me weird I know just a phobia I have. For instance I would buy used calipers but get everything else new ... just the kind of guy I am I can't explain it :dunno:
  17. Nuke
    i see whut u did durr :laugh::laugh::laugh:
  18. Paul Revere
    Bump for more questions.
    Where should I buy this stuff I have been looking on all the sellers websites gruppe-s, tirerack, fastwrx, jscspeed, oakos ...
    Looking to get front rotors, pads f&r, lines, fluid and a master cylinder brace.
    *Found Sheens post*
  19. Bielke55
    I can log into tirerack wholesale still for a discount there.
  20. Paul Revere
    Sweet sweet!! you will have a pm later I have to head out for the day.
  21. retreif
    I have hawk pads, ss lines and am looking to buy new disks. Let me know where you find the best deal. Wanted to get the Cyro powerslot disks.
  22. Paul Revere
    Wagner where did you tell me to get rotors?
  23. Mike Wagner
    CVR Motorsports, or Diversified Cryogenics
  24. Mike Wagner
    Don't you already have rear rotors?
  25. Paul Revere
    Yeah but I need fronts y0!
  26. Mike Wagner
    Did you install BOV yet?
  27. Paul Revere
    Yep at 10pm in the dark, real simple install though!! The wrong spring was in it though but Sheen set me straight on the springs. Also its a BPV not BOV ... jeez Mike.
  28. retreif
    Are you doing the brake install yourself?
  29. Scuba Steve
    Chet's car will not let him work on it. He pawns the actual work off to me or others like Mike
  30. Paul Revere
    Hahaha ... what he said :(
  31. retreif
    Well I have done a brake job once in my life. Replaced the pads on a '68 Beetle 28 years ago. Speedometer never worked again. Didn't have the interwebz then though. Still not sure I have enough courage to try.
    what kind of brace are you thinking? how hard are they to install?
  32. Back Road Runner
    I run Carbotech AX6 pads with WRX front and H6 rear rotors/brackets. My only complains are that they are noisy without a religious use of some form of anti-squeal (Brake Quiet, anti-sieze, bearing grease, etc.). Auto-x events tend to burn off/dry out most anything put on.
    Friction level is a touch above stock dead cold. "Normal" operating temp is just above normal driving, but when heated, they grip very well. Once you get them hot, braking effort is rather light even under heavy braking with grippy tires, running 245 wide RE01Rs myself. The non-linear friction/temp behavior may not be all that desireable to some, but one does get used to it relatively easily.
    I have yet to find a need for more braking ability and the WRX + H6 bias is really very near neutral.
    I haven't had any issues with heat or fade with auto-x. I think I'd have to get to track use to ever see thermal problems.
    The brakes are incredibly light on the rotors and the pads themselves wear like iron. The setup will effortlessly last many years. The aggressiveness between pad and rotor wear is really good, and for the braking ability, I find overall wear to be rather quite light.
    The pads do dust a bit, something to think about if you're a clean freak.
  33. Bielke55
    Hey OCB!
    Come get your HPS maxi Pads!
  34. Scuba Steve
    if he doesn't come get them soon I'll take them;)
  35. Ylime
    I will take them as well....so hurry up chet.
  36. Paul Revere
    Wouldn't fit your car Em but good try!
