Brakes?
Discussion in 'Modifications And Maintenance' started by ortho004, May 30, 2011.
  1. ortho004
    ortho004 Well-Known Member
    So I was in the process of taking a look at my brakes until a severe thunderstorm rolled in, so instead I thought I would post a quick question about this.
    Car: 2002 Subaru RS
    Mileage: 115,000
    Cause for concern: After driving home from work (5 miles or so) I get a horrible squeal/screech from my passenger side rear wheel. Only happens when I am just about home puling into my garage, not at all before then. It is not constant for my whole drive, only (it seems) after I have been driving for a few miles. Last week when I first noticed I had driven maybe 30 miles, and the rim was warm.
    Other notes of importance: The pads and rotors were replaced 4000 miles or so on the back wheels, last fall if I remember correctly.
    Any ideas why the noise would come after some driving? Anything specific I should look for with the brakes past pad wear and a stuck caliper? Could it be deterioration of the soft brake line (only reason I ask is a friend just went through this causing a caliper to seize)? Parking brake not disengaging? Something else?
    Your input/experience is appreciated. Thanks for your help, hopefully this storm passes soon and I can get back out to look at it on my only day off this week...
  2. Mr.Tran
    Mr.Tran Well-Known Member
    Check the brakes and rotors for normal operation, to me it sounds like it may be something else. Wheel bearing perhaps?
  3. ortho004
    Update: Took the wheel off, and the rotor is not spinning freely, it takes both hands and a lot of effort to spin it, but it will spin.
  4. readymix
    I hope you have the car completely suspendeded off the floor.
