Brembo help!
Discussion in 'Modifications And Maintenance' started by jdm4you, Jul 14, 2009.
  1. jdm4you
    jdm4you New Member
    I'm looking at getting a set of brembo off of a 2005 STi. I know the rotors will not work and I'll have to get 04' STi rotors. What I wanted to know is if any one on here know's what else I need to blot them up. I though that they blotted right to the stock mounting point as my 4pots but I could be wrong. Please let me know guys! Thanks.
  2. Boosted Bugeye
    Boosted Bugeye Member
    What is the car (assuming WRX, but what year...) that are you putting these on?
  3. Moleness
    Define "blotted"?
  4. FuJi K
    They bolt right up to your WRX fronts. They even bolt right onto my '99 L front spindles!
    Just get Rotors for '04 STi. Time to grab some 2piece rotors with good pads.
  5. jdm4you
    jdm4you New Member
    Sorry. It's a 2002 WRX.
    Bolted. My fingers move faster the my brain some times.
    So there are no spacer's need or calliper bracks? Just pull off the one's that are on there now, new rotors and put the new brembo's on? I just don't want to getting these and then find out I need all this extra stuff to put them on.
  6. FuJi K
    correct, just bolt on the Brembo calipers on, put your brake lines on, pads and rotors. All good to go!
  7. wrx_traut
    wrx_traut Well-Known Member
    dont you need a mount for the rears? since the sti rotors are bigger than a stock wrx they wont fit, you need a 04 sti rear hub or you can make/buy a mount.
  8. jdm4you
    jdm4you New Member
    Thank you sir!
    I'm just doing the fronts for now. I just put new racing brake rotors and hawk pads on the rear.
