Broken Bolt Help.
Discussion in 'Modifications And Maintenance' started by Navar Hren, Aug 17, 2016.
  1. Navar Hren
    Navar Hren Active Member
    I done goofed. Well, maybe it isn't my fault, but the fault of MNDOT. Attempted to install a new rear swaybar today and the very first bolt snapped right off despite several coatings of pb blaster in the past few days.
    So, I'm hoping to find someone with a few tools and the experience to help me out with this.
    The culprit:
  2. silver03
    Is that the bolt connecting the sway bar to the end link or the bolt connecting the endlink to the lower control arm?
  3. Navar Hren
    That's the bolt connecting the swaybar mount to the chassis. The worst. I got new STI mounts with the sway bar I picked up and was swapping the whole set at once.
  4. JasonoJordan
    You know who has the tools to help lol
    sti-fighter and Navar Hren like this.
  5. sneefy
    sneefy Well-Known Member
    Funny. I did the same thing to my old 2002. I bought new Whiteline sways and reinforced brackets for the rear. I made the mistake of doing this on a car with 90k miles that had lived in salt country it's entire life. One of the bracket bolts snapped just like yours. I ended up drilling it out and just fishing a bolt through the frame rail to the bracket. Worked just fine.
  6. Navar Hren
    Not a terrible idea if I can't drill it out and everything successfully. Drivers side mount came off ezpz but was clearly replaced recently; probably hasn't seen a winter yet. Passenger side is the pita and of course is tucked up above the charcoal canister. I haven't attempted the second bolt on this one yet. Hoping it just eases out unlike it's mate.
  7. retreif
    try heat next time.
    Navar Hren likes this.
  8. pillboy
    As in a gallon of gas and a road flare.
  9. Fatboy Walrus
    Fatboy Walrus Well-Known Member
    When I replaced the endlinks and bushings to poly on my Saabaru every F***ing bolt snapped. It was HELL. Ended up taking day off of work. Buying several same size drill bits, tap and die set and fixed it. SOAK everything in PB. torch it if need be and be patient.
    silver03 likes this.
  10. Navar Hren
    Drilled that sucker out today. Piece of cake. Only complaint is that I wasn't perfectly center and my hole ended up a hair too large. Going to drop a nut on top of the bolt inside the frame.
  11. ShortytheFirefighter
    Let's not make changes to the formula. It calls for five gallons, you want to make sure that you get it going completely.
  12. pillboy
    I wasn't gonna condemn the whole project for one broken bolt.
    Krazylegz1485 likes this.
  13. Shane86
    Shane86 Well-Known Member
  14. retreif
    "chowdered right the ****"
