Broken Wheel Studs 2006 STi
Discussion in 'Modifications And Maintenance' started by Flat4, Apr 17, 2009.
  1. Flat4
    Flat4 Well-Known Member
    Bloomington
    So yesterday I was pulling off my winter wheels and broke a wheel stud on my front drivers wheel and one on my rear passengers wheel was cross threaded so i think i may need a new stud there.
    My question is:
    How hard are they to replace?
    Does anyone have one laying around? I called a dealer and they said no one in 100 miles have any.
    Thanks,
    Jake
  2. TSTRBOY2004
    call Napa or an aftermarket shop...
    you will have to remove the calipers and rotors...
    hammer out the stud.. put new one in.. issues is you need to tighten it down enough that it seats before tightening on your rims...
  3. Flat4
    Bloomington
    Would it be bad to do light driving with only 4 lugs on?
    Dont they sell a tool to seat the studs?
  4. Scuba Steve
    In the Co-Driver Seat
  5. Flexure
    Flexure Member
    St. Paul
    It probably would not hurt anything to drive it. Just make sure the other 4 lugnuts are tight. I personally would not drive a 06 sti on only 4 studs though... Not worth the risk imo
  6. Scuba Steve
    you could techincally drive it all day long and forever on 4 studs....i wouldn't worry about it. Just wouldn't drift it all day every day
  7. piddster
    Boostonia
    I've replaced several studs over the years from shops overtightening the lug nuts. I just use a large nut that fits over the threads of the wheel stud and an open-ended lug nut to pull her home.
  8. TSTRBOY2004
    bingo.. yes they do sell a tool with a bearing built in so it spins with the nut as it tightens so as not to score the lug-nut... but you can do it with a washer or larger nut as a base...
  9. pksublime
    pksublime Well-Known Member
    and yes the freezing trick helps, the stud will be just a little bit smaller and will go in ever so much easier
  10. Chux
    Independence, MN
    I drove my wagon around town for a few weeks with only 3 studs on each rear hub....stupid XT6 studs being impossible to find.
  11. Flat4
    Bloomington
  12. carl
    we gotta gooooo
    to pop the rotor off the hub (they get corroded together). you may not need to do it if you've done rotors very recently - or you can beat on it with a hammer but I'd use the screws over that method
  13. Scuba Steve
    The WRX and STI has the E-Brake pads/assembly inside the rotor. You'll need to insert the two screws in the holes and thread them in, which in turn will push the rotor off the assembly. MAKE SURE YOUR E-BRAKE LEVER IS DOWN otherwise you'll have a long fight on your hands. :biggrin:
  14. carl
    we gotta gooooo
    yes that's an important detail, take the ebrake off lol.
  15. AWDimprezaL
    Monticello.
    LOL u mad?
  16. Flat4
    Bloomington
    Lol i was really pissed when it snapped and my hand slambed on the garage floor
    Are the fronts easier to replace then the rears?
  17. AWDimprezaL
    Monticello.
    About the same, fgt.
  18. austinpike
    austinpike Well-Known Member
    Oakdale, MN
    fronts are easier, no ebrake and there is more room to work.
