Brooklyn Park Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by ShortytheFirefighter, Jul 2, 2005.
  1. Shane86
    Shane86 Well-Known Member
    I'm thinking about it.
    acording to ravensblade, those first two part numbers are the whole caliper/bracket asembly.
    Thanks man, i'll keep this in mind.
  2. 02blubru
    Do the these discounts apply to the subaru body shop?
  3. ShortytheFirefighter
    I haven't been able to talk to our body shop about a discount. Things get tricky there because they mostly work with insurance companies rather than a paying customer. Also, their pricing/labor is different than ours, so I'm not sure if I'd be able to work something out with them.
  4. John16V
    John16V Well-Known Member
    Have you find out anything about the defrost bulb? Thx
    Do you have the stock exhaust flange in stock?? (that metal plate thingy that connect the exhaust and mid pipe together)
    thx,
  5. 02blubru
    That car is fixed, thanks though Brian.
  6. Dynapar
    whatcha got for a price on a rear swaybar w/ bushings for a 95-99 outback? probably dontneed endlinks.
  7. ShortytheFirefighter
    John, no luck yet on the bulb. I'll keep checking to see what I can find.
    Martin: The biggest rear sway I can find is off of a 99 Outback, it's an 18. The part number is 20540AC090 and your cost is 107.62 + tax. The part number for the bushings is 21047GA671 and you're at 7.92 each. I'd have to order them in.
  8. Dynapar
    ok, thx. i will hold off for now, but maybe closer to april i will hop on that.
  9. 3fordasho
    3fordasho Active Member
    Hi Brian,
    Hoping you can quote some parts, victim is a 02 WRX (wife's) and has cracks in both cylinder heads.
    Please quote:
    both heads, (I assume they come as bare castings)
    8 each intake and exhaust valves
    Gasket set (head set if available, or complete)
    thanks!
  10. ShortytheFirefighter
    Tim, PM'd you.
  11. ShortytheFirefighter
    Alright Tim, here ya go:
    L Head: 11039AB361 514.48
    R Head: 11063AA841 514.48
    The pricing on those isn't quite 20% off, there isn't enough markup for that so we split the difference between cost and list. We do the same thing for engine shops. For some reason Subaru doesn't mark up things like shortblocks, heads and transmissions very much.
    Intake Valve: 13201AA391 13.22 each (5 in stock)
    Exhaust Valve: 13202AA401 16.50 each (7 in stock)
    Gasket Set: 10105AA351 247.78 in stock
    That's the complete gasket set for the engine. Let me know if you just want the head gaskets/valve covers, etc. Those prices are without tax. Thanks, Brian
  12. LVT
    LVT Well-Known Member
    brian, give me a price qoute for the rear passenger hub/spindle assembly for my RS.
  13. LVT
    edit: opps double post.
  14. ShortytheFirefighter
    Post whore! J/K ;)
    Alright, here's the whole price breakdown for everything in there, in case you need more than just the spindle...
    Axle nut: 28044AA000 3.50 in stock
    Rt Rear Axle Housing: 28411AA000 134.54 special order
    Oil Seal: 28015AA090 8.36 in stock
    Oil Seal: 28015AA100 8.10 in stock
    Oil Seal: 28015AA110 9.00 in stock
    Bearing: 28016AA030 59.60 in stock
    Snap Ring: 28035AA040 4.76 in stock
    Hub: 28469FE000 95.96 in stock
    That's everything in that rear assembly. I'm not sure how much you'll need to replace, but if you tweaked that housing enough you'll probably find that the bearing got damaged also. Just let me know what you need. Thanks!
  15. Dizmal
    Dizmal Well-Known Member
    I need some anti freeze and oil filter for 02 wrx
  16. ShortytheFirefighter
    Dizmal, here ya go...
    Oil Filter: 15208AA100 7.16 in stock
    Crush Washer: 11126AA000 .88 in stock
    Subaru Coolant: 11.78 per gallon in stock
    Just mix the coolant 50/50 with some distilled water.
  17. PaulasaurusREX
    Hey Brian
    I've been looking for a decent price for the OEM lip kit for 02-03 wrx's but haven't fuond a cheap price as of yet. Considering the parts are OEM I guess there just won't be a cheap price on them. Just wondering if BP Subaru could order these parts and how much they are? I'd need the front and rear lips. Also is there a subaru website that iists these parts so that I wouldn't have to bug ya and for other OEM parts that I could possibly add?
    Thanks Brian, car is running great and I will soon be moving to Maple Grove right up the road from the BP store so I might be swinging oil changes and what not in the very near future. And a test drive or two, why not.
    Forgot, here's a link to a pic of what i'm looking for if I wasn't clear above.
    http://forums.nasioc.com/forums/showthread.php?t=939146
    Although these pics are of a wagon I do have the sedan, but them pics make me wish I had a wagon
  18. ShortytheFirefighter
    I'll look them up tomorrow when I get back in, with the discount they're not too bad pricewise IIRC. What part of teh Grove are you moving to?
  19. phi11
    looking for a part # and cost.
    '99 SUS front grill
    _|_|_|_|_|_|_|_|_|_|_|_|_|_|_|_|_|_ (17 bars X 2 bars)
    looks like this:
    Thanks.
  20. PaulasaurusREX
    The Grove
    I'll be right off Zachery Lane, right across the street from Elm Creek park reserve. So just north ya. The move will be made mid march or so. So if ya happen to see an 02 black debadged wrx driving around its probably me. Also just installed white sidemarkers and wiil be ordering up some screened fog light covers soon as well.
    Thanks for the info Brian
  21. Dynapar
    hey brain i am looking for another passenger side valve cover gasket. any idea on a price?
    thanks
  22. Chux
    ignition amplifier for '88 SPFI EA82 (little electronic gizmo under the coil)
  23. Dynapar
    Hey Brian i am gonn abe stoping in today around 12:20 or so.
  24. ShortytheFirefighter
    Alright, here we go:
    Paul: They don't make the OEM front lip/rear lip in MBP, so this part number is for a white one. You'll need to get them repainted to match your car.
    Front: E2410FE201WG 307.71 Sp Ord
    Rear: E5610FE200WG 383.57 Sp Ord
    Fog Covers: ST577104S000
    Phi11:
    Front grille: 91061AC300 183.98 Sp Ord
    Matt: I can't find it in the catalog. Can you get me some more info? What kind of car is the motor from? Are there any numbers on the part itself? Thanks, Brian
  25. Dynapar
    Brian i need more parts lol.
    this time its the oil pan gasket for a 95 impreza 2.2l
    and just for a reference how much for the actual oil pan?
  26. Chux
    oh, sorry about that, I found one in the parts out in the shed....so I don't need it
  27. PaulasaurusREX
    Thanks Brian
    Thanks for the quote I'll have to save them pennies up here, maybe for summer. Have a good one!
    Thats a bummer they don't make them in MBP. I suppose they only have blue, white and silver or something, lame.
    Have a good one
  28. Dizmal
    I want to install my Alpine and I need the Legacy pocket center for the radio.
    I think its part # 66120AE050
    That should fit MY02 WRX right? The Alpine is single din.
  29. ShortytheFirefighter
    Yeah, the pockets are single din and the dash slot is a double din, so it'll work. The price is 20.42 and I have it in stock. Just let me know. Thanks!
  30. LVT
    brian, qoute me a 2000-2001 2.5RS bumper and RS coupe wing.
  31. Shane86
    Brian,
    Do you guys have any access to just some rattle cans of Subaru colors?
    i'm painting my helmet, and i think it would look really cool in WR Blue with some yellow accents.
  32. Dizmal
    Brian, are you going to be around tomorrow night? After 6pm? I was planning on picking up a jug of Aniti Freeze and the Legacy pocket center for the radio.
    Let me know if that will work.
  33. ShortytheFirefighter
    Lue: I'll post them up tomorrow when I get to work.
    Shane, We don't have rattle cans of the paint. However, there is a place on Central Ave south of 694 called Welle Auto Supply. They can mix up a can for you right there, and they do good work. It's about 20 bucks for a spray can, and they do a great job of matching the color. You may want to bring your paint code (O2C is WRB, IIRC) and they'll get it mixed for you. I've still got a can of Sedona Red, it's what I used on my fog covers.
    Dizmal, we actually close at 6pm but I'm the closer so I'll be there until then. If you want, give me a ring tomorrow and we can either do the transaction over the phone and I can leave it with the receptionist, or we can figure something else out. I've got to run after work because I'm helping out our new firefighter class with ladders, they needed someone to run the Aerial. Just let me know. Thanks!
  34. ShortytheFirefighter
    Lue, the part number you'll need is 57720FA280 and the price is 167.96. I'll have to order one in, but Brian at Mtka shows one in stock. I can have it here by Monday if you're not in too big a hurry. Just let me know. Thanks!
  35. LVT
    uhh..is that the coupe wing or bumper? also this was a qoute for a friend.
  36. ShortytheFirefighter
    Shoot, knew I forgot something. That was for the bumper. The coupe wing is an E7210FA000NN and your price would be 344.61. They come unpainted.Will you be needing the third brake light and all of the mounting stuff as well?
  37. LVT
    woah that is insane for a coupe wing...but sure all those in. a friend of mine wants to know so he can consider it.
  38. asiandude
    asiandude Well-Known Member
    how much for a passenger side mirrow? for 99L i broke fuji LOL
  39. Dynapar
    hey brian, i need a price check. crank shaft positioning sensor for an 95 impreza ej22.
  40. Chux
    clutch cable for my '88 wagon
  41. beeloo
    beeloo New Member
    Brian,
    You have a pm!
  42. ShortytheFirefighter
    I'll get this stuff looked up today when I get to work. I was going to try and go in yesterday, but I spent most of the day at the station running medicals since squad cars don't go through snow so well. Thanks guys.
  43. Dynapar
    brian, dont worry bout my request. i went to napa and got the sensor for $30. it didint fix my problem.
  44. AspitFire
    hey brian, how much for gaskets for doing an up pipe installation.
  45. ShortytheFirefighter
    Alright, here we go. Sorry for the delay...
    Asiandude: I'll need a VIN to make sure, but this should be the right mirror.
    91031FA360NN 111.96 SOP
    Matt: 37026GA081 16.44 SOP
    Beeloo: Studs 800910390 2.68 each I have 2 in stock, Mtka has 2, check with Matt. He might have some down at his shop. We can always order more for him.
    Downpipe gaskets: 44011FE000 7.12 in stock
    44022AA180 16.44 in stock
    Uppipe gaskets: 44022AA150 10.78 in stock
    44022AA170 10.78 in stock
    Bulb: 84920FE000 4.76 in stock
    Give me a call when you get a chance, I'll be here until 6pm tonight and tomorrow night and from 8-4 on Saturday. We'll get you squared away for your install. My direct line is 763-582-7462.
    Aspitfire: the uppipe gasket are the sames ones listed for Beeloo. I've got multiples of both.
    Thanks guys!
