Brooklyn Park Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by ShortytheFirefighter, Jul 2, 2005.
  1. ShortytheFirefighter
    We're open until 6pm weeknights and 8-4 on Saturdays.
  2. mndude
    mndude New Member
    I really need just plugs/fuel filter but what is included in 90K maintenance?
    Thx
  3. Chux
    thinking about replacing all the wheel bearings with the 5-lug conversion. at least the rears, since those will be 85,000,000x easier with the trailing arms out.
    rear wheel bearings:
    906100007
    seals:
    062440528
    28015AA100
    2 each
    maybe fronts too:
    28016AA011NT
    seals:
    28015AA080
    28015AA070
  4. ShortytheFirefighter
    MNDude, the full 90k maintenance (actually, since you need plugs it'd be a 60k) would be right around 750ish. It'd be replacement of all the fluids in the car, plugs, new air filter, new fuel filter, etc.
    906100007 84.76 each sp-ord
    seals:
    062440528 6.08 each sp-ord
    28015AA100 8.10 each in stock
    2 each
    28016AA011NT 59.60 each in stock
    seals:
    28015AA080 8.56 each in stock
    28015AA070 7.06 each in stock
  5. Chux
    :eek3:
    maybe I'll just repack them and take my chances!
    I'll probably get new seals too. I'll give you guys a call when I decide what I want to do.
    thanks!
  6. ShortytheFirefighter
    No worries Matt, just let me know :)
  7. 02blubru
    ok brian, how much for the optional front lip from subaru for an 02 wrx in wrb color? I hope you know what I am talking about because that is the best I can explain it.
    I think this is the part number E2410FE201PG
  8. ShortytheFirefighter
    Bill, I'll have that up for you tomorrow when I get in. Thanks!
  9. Colin
    Colin Well-Known Member
    Brian: I am in need of either a set of stock EG33 engine mounts, or a set of something stiffer that would fit. was wondering price and availability.
    thanks
  10. 02blubru
    BUMP...
  11. ShortytheFirefighter
    Bill, looks like 300.05 + tax for the front spoiler, retail is 377.16. I have to order it.
    Methodless, the part numbers are 41022PA000 and 41022PA010, 176.44 + tax for each of them. We don't have either of them in stock.
    Sorry for the delay guys, I didn't get in here until 2pm today. I hate migraines...
  12. 02blubru
    ^^ no big deal, hope you are doing better now.
  13. ShortytheFirefighter
    Meh, I still feel like I mouthed a concussion grenade but I'm still vertical so I can't complain too much ;)
  14. jubella2
    jubella2 GC8 FTW
    Brian- I was in quite a while ago and had my leak diagnoised as a driver side head gasket leak. I was looking at the sticky and it said for 99+ i could use a coolant conditioner. Do you carry that and if so what is the price on that? but I'm no mechanic but it seems my car is dripping oil rather than coolant. So would this coolant conditionor even help? I also replaced the passanger side valve cover gasket a while ago with no luck stopping the drip so should I maybe try the drivers side valve gasket?
    Thanks.
  15. ShortytheFirefighter
    We've got the coolant conditioner, it's only a couple bucks for a bottle of it. I don't think it'll do anything for your oil leak though. When you did the V/C did you do the spark plug boots as well? Have you been seeing any sort of leak on the drivers side? Checked the oil pan for any leaks there, or the crank seal/oil pump? I'd check along the lower edge of the front timing cover, I'd put my money on a leaking oil pump. What year/model/miles are you running?
  16. MrMcMonkey
    MrMcMonkey Well-Known Member
    Brian -- price quote for brake pads (front and back) for a 2003 legacy sedan... and fog lights for an 07 wrx. thanks
  17. ShortytheFirefighter
    MrMcMonkey: The front pads are 26296AE160 and they're 71.96 + tax, the rears are 26696AE020 and they're 67.96 + tax. I'm out of stock on the fronts at the moment but I'll have more by Friday.
    For the fogs, I'll need the paint color to get the correct fog light covers as they come painted. The fog light kit is a H4510FE030 and they're 220.80 for the kit. The covers are 63.20, I just need your paint color. I'll have to order both. Thanks!
  18. jubella2
    jubella2 GC8 FTW
    Yes I replaced the spark plug boots at the same time. I cleaned the bottom of the engine and it seems to be getting gunked up on the drivers side. The drip seems to hit the exhaust header right before the two sides meet. I'll check under the timing cover tomorrow but I think the leak seems to be coming more from the rear of the engine. I have a 99 2.5 RS with just over 72k miles. I may swing in next time I'm in the area and give the coolant conditioner a try. Couldn't hurt.
    Thanks
  19. MrMcMonkey
    awesome...i'll be in on monday for the brake pads...not sure about the fogs yet
  20. RallyImp05
    RallyImp05 Well-Known Member
    30000 mile maintenance
    how much would the 30000 mile maintenance run on my 05 RS? i want to go full synthetic?
  21. ShortytheFirefighter
    The 30k usually runs around 750ish with the discount. You'd probably be better off picking up your own fluids, it'd be cheaper for you that way.
  22. k_thaosta
    k_thaosta Well-Known Member
    how much for the alternator/ps and the ac belts?
  23. Bielke55
    $18.69 I/S both locations
  24. predavore
    predavore Well-Known Member
    Just stopped by and picked up a cabin filter. Thanks Brian. This discount is definately nice to have. Thanks.
  25. ShortytheFirefighter
    Anytime Derek :)
  26. mlgez
    mlgez Well-Known Member
    Hey thanks again Brian. Hope to get those in before the weekend. Oh and have fun driving the 08..... lucky
  27. jubella2
    jubella2 GC8 FTW
    Brian- I get a P0325 code every once in a while. Goes away when I run premium gas but comes back on with 87 octane. Any ideas? I shouldnt have to run premium in an RS right?
  28. ShortytheFirefighter
    No, you shouldn't...I'll look up that code when I get in tomorrow and see if the guys have any ideas. What year/model/miles/mods?
  29. MCJT
    MCJT Well-Known Member
    Brian saved me about $700 today on my purchase. Thanks!
    JT
  30. jubella2
    jubella2 GC8 FTW
    99 2.5 rs with 72,XXX
    Thanks
  31. ShortytheFirefighter
    P0325 is a knock sensor circut malfunction code. You need a knock sensor. 22060AA070 is the part, I've got 4 on hand. 78.36 + tax is your cost.
  32. jubella2
    jubella2 GC8 FTW
    okay. Today there was no CEL so I will hold off a little bit but thanks for the info.
  33. Bullwinkle
    You guys sell SPT parts? I'm looking to price some SPT "pink" springs for my '06 WRX Sedan.
    I think it's part number(s):
    B2010FE500 (2)
    B2010FE510 (2)
  34. ShortytheFirefighter
    I should have a set of those on hand, I'll check on Monday. I'm 99% sure we do though. IIRC it's around 60ish per spring, but I'll verify that for you ASAP.
  35. 02blubru
    hey how much for a flasher relay??? Mine died....
  36. 02blubru
    never mind I found the problem. blew the hazard fuse and the turn signal fuse, a quick check of the horn verified the hazard fuse and a quick check of the windows verified the turn signal fuse...
  37. ShortytheFirefighter
    I've got all 4 on hand. They're 59.00 each + tax. Come and get 'em :)
  38. mlgez
    Sure now your back. Was down in the cities for about 4 hrs and you weren't there :)
  39. ShortytheFirefighter
    Yeah, I was out driving parts this morning. Heard you were looking for me but I didn't get back until almost 1pm.
  40. mlgez
    Guess I should have called again. Left MG arounf 1:15. Oh well, tomorrow?
  41. ShortytheFirefighter
    I won't be in all day. I'll be working Safety Camp for the FD. I'll be in from Wed-Sat though.
  42. jubella2
    jubella2 GC8 FTW
    Brian-
    Having problems yet again. The CEL was off for quite a while but I'm getting the same code again. Although this time the car starts and idles really rough and has almost zero throttle response. Could the knock sensor code possibly indicate a bad fuel pump?
  43. ShortytheFirefighter
    Doubtful...I may be off base, but if the knock sensor is bad and sending faulty data to the ECU it may cause the ECU to start altering timing/spark stuff and cause the engine to run poorly. I could be wrong on that. It could be a combination of both a CEL and a bad fuel pump together though.
  44. jubella2
    jubella2 GC8 FTW
    Do you still have the part in stock? I will be swinging in sometime during the next few days.
  45. ShortytheFirefighter
    Yup, I've got a few of them. I've got the part number and price in post 706.
