Brooklyn Park Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by ShortytheFirefighter, Jul 2, 2005.
  1. crosschofas
    crosschofas New Member
    60k car check
    hey, brian, I just bought an 02 WRX from Mplsrex, about 6mnths now. I need to bring my car in for a check, on what I need done. do I need to schedule an appointment? it seems to lag on 1&2nd gears. don't feel to much power, fluid check too. maybe a turbo clean. you tell me.
  2. ShortytheFirefighter
    I have yet to hear of a turbo cleaning. I'd give service a call in the morning, 763-582-7455 and tell them who you are and that you're a club member. Tell them what problems you're having and what you'd like changed as far as the fluids go. They'll get you an appointment and an estimate.
  3. Chux
    rear diff pinion seal. I suspect any R160 will be the same....but if it matters, this diff is from an '88 RX
  4. ShortytheFirefighter
    Looks like an 806735270, I've got 2 of them in stock. 14.78 + tax. Just let me know. Thanks!
  5. Chux
    got it today (as in, called yesterday, and a little box was on my porch when I got home from work). Thanks a ton!!
  6. silver03
    I will need 2 Group N tophats for my 03 WRX sedan shortly (within the next 7 days). In stock? Price with tax, title, license etc? Thanks
  7. ShortytheFirefighter
    Will you need fronts or rears?
    Fronts: B0310FE000 59.96 + tax each, 1 in stock. I can have a second one here by Monday.
    Rears (02-03): B0310FE010, B0310FE011 (RH and LH): 95.96 + tax each, special order
    Rears (04+): B0310FE013 x2 103.96 + tax 2 in stock
    Let me know what you need front or rear, and if it's rears, let me know what springs you'll be running. That'll determine what mounts you need. Thanks!
  8. silver03
    ^^ I will need just the fronts. Please order. Thank You. Oh, I will be running Prodrive springs on KYB AGX struts.
  9. ShortytheFirefighter
    Sounds good, they'll be here on Monday :)
  10. Chux
    OK, got a list for ya (sorry....big project....old parts)
    Wrench 925550000 (for removing rear wheel bearings, I'd kind of like the real thing)
    I'm also looking for the ~8" long brake hardlines that run along the rear trailing arms. They should be the same for any EA82 with rear discs (4-cyl turbo, or XT6), these trailing arms happen to be from an '86 XT turbo. I got some prebent hardlines from toyota for my 4Runner for a reasonable price, so maybe you guys can do the same....
    I think the rest is wheel bearing stuff that you already looked up for me.
    I'll be placing an order before too long that I can hopefully pick up when I'm in town in a couple weeks.
  11. ShortytheFirefighter
    I'll check it out tomorrow morning when I get in :)
  12. silver03
    The wife is coming to get my tophats tomorrow...they're in?
  13. ShortytheFirefighter
    They should be, I'll shoot you a PM tomorrow to make sure.
  14. dipp
    dipp Well-Known Member
    could you look up a price for fog light covers for my 99 2.5 RS im sure ill need the brackets to mount them too. plus do they come already painted?
  15. rsverv
    rsverv Well-Known Member
    i want to know the availability and prices on the following parts for my 01 rs.
    *sti group n strut mounts front/rear
    *brakepad hardware kit (solid/vented shims and brakepad clips) front/rear
    *fender well blocking plate
    *dual port header gasket (engine block to header)
    *header gasket (header to converter)
  16. Chux
    thanks man. thought of some more stuff while I was at work tonight
    also looking for a 21 (full set +1) of Acorn lug nuts. all the ones I have are the nasty ones to be used under a wheel cover, and I only have 16 of them. aswell as one front lug stud for a '94 legacy, and a rear one for an XT6 (maybe different lengths?)
  17. ShortytheFirefighter
    Alright, from what I can tell, the hardlines are a 21075GA052, and they're 82.26 + tax each with club pricing. I want to check with Subaru, as I think they may be mis-listed in the catalog. They come up listed as outer arm assemblies, but the picture/part that I'm pulling up is obviously a hardline. I'll let you know. I'm also going to have to get back to you on the wrench, the pricing comes up as 0.00 dollars.
  18. ShortytheFirefighter
    Oops, just caught this. The rear stud is a 23621GA020 and they're 3.16 + tax. I'd need to order that in. The front is a 28055AA003 and they're 2.02 + tax. I have them in stock here. The lug nuts are 623006021 and they're 1.80 + tax each. I've got 9 here, I would need to order the rest in. Just let me know. Thanks!
  19. ShortytheFirefighter
    Those might be an aftermarket/JDM option, I'll have to do some checking. I'm not finding them in the parts catalog at the moment.
  20. Chux
    good grief! I barely paid more than that for 3 hardlines that went the length of my 4Runner......the ones I need for the subaru are tiny.
    the wrench (they call it a wrench...but it should be a socket) part number is directly from an '88 FSM.....
    you're the best man! if it weren't for you....I'd be putting Napa reman's everywhere....and my car would fall apart.
  21. ShortytheFirefighter
    Fronts: B0310FE000 59.96 + tax each, I'm sold out at the moment
    Rears: B0310FE010,FE011 95.96 + tax each, I'm also sold out of those (The two part numbers are because they're right and left specific.)
    They don't sell the hardware kit seperately, you'd have to buy all the clips/shims seperately. It looks like it'd be 46.00 + tax for the fronts, (26232AC000 x4, 26233AA110 x4, 26233AA120 x4) and the rears are 34.32 + tax, (26632FC001 x4, 26633FC000 x4, 26233AA030 x2) and I'd have to order all of them in.
    46059FA000 1.86 + tax, special order
    44011AC020 5.14 + tax each, I've got them in stock
    44165FA000 6.14 + tax in stock.
  22. rsverv
    ^^^ thanks!!! i'll stop by today to pick up the gaskets.
  23. Chux
  24. ShortytheFirefighter
    I found out today that we're not able to get Subaru tools through the parts department, but you can get them direct through Kent-Moore. I'll try to find a site for them for you.
  25. badbennyb
    Group n tranny mount. Price,availability? oh yeah 6spd but you probably knew that.
  26. Chux
    and the lug nuts/studs.
    I'll be in town next Wednesday. have them by then?
  27. ShortytheFirefighter
    The special order stuff I would have to 2 day or overnight to have by Wednesday, the stock order cutoff was yesterday. I'll see if I can cut you a break on the extra shipping, I'll have an answer for you this afternoon.
    Badbennyb, the tranny mount is a D1010FE000 and they're 67.16 + tax. I'll need to order it, it'd be here by Thurs/Friday.
  28. silver03
    Motor mounts cost 00 2.2L Impreza. thanks
  29. ShortytheFirefighter
    41022FA091 x2, they're 80.24 each + tax and I'd have to order them in. Thanks!
  30. matt_wong
    matt_wong Well-Known Member
    How much is 20401XA00A Tribeca Front Sway Bar
  31. Chux
    yea.....I'm gonna wait and just have you guys ship it to me. it'll just be easier.
  32. badbennyb
    Brian, could you order this for me?:)
  33. ShortytheFirefighter
    Those are 57.94 + tax, just let me know. Sorry for the delay!
  34. ShortytheFirefighter
    For those of you who have been wondering about parts pricing or ordering parts, I apologize for not getting back to you sooner. I've been out sick and dealing with some family issues so I haven't had a chance to keep up with this. I'll be in Seattle through Monday for a funeral, so if you need anything from here just give Brett a call at 763-582-7462 and we'll get you taken care of. Matt and BadBennyB, your parts have been ordered and should be here on Monday/Tuesday, depending on cross-shipping. Thanks!
  35. badbennyb
    Thanks Brian. Good luck with everything.
  36. matt_wong
    Are they in stock or do you need to order it.
  37. ShortytheFirefighter
    We would have to order one in, call Brett on Monday and he can get one coming for you by Thursday. Thanks!
  38. predavore
    predavore Well-Known Member
    Brian,
    Can you get me part numbers and prices on the PS and AC belts for an 02 WRX?
    Thanks,
    Derek
  39. BBsRS
    BBsRS Well-Known Member
    Brain can you Pm me a list and prices for whats required to do a timing belt and whatever is involved ie idler, tensioner?? etc. also cam oil seal for a 2000 RS.
    Thanks,
    Bee
  40. ShortytheFirefighter
    Hey Derek, the numbers are:
    A/C: 73323AC000 10.36 + tax in stock
    P/S: 809218370 11.02 + tax in stock
    Thanks!
    Bee, you'll have a PM tomorrow morning.
  41. ShortytheFirefighter
    Alright, quick update for everyone. Some of you know that one of my aunts was in a car accident last week, she's stabilized and expected to pull through. I found out yesterday after I got back from Seattle that another of my aunts was broadsided by a dumptruck that ran a red and was killed. I'll be in and out of the department this week so parts requests might be delayed until next week when I get back from Utah. If you need parts right away give Brett a call here at BP at 763-582-7462, or give Erik and Brian a call down at Minnetonka, 952-797-1362.
  42. tangledupinblu
    Sorry to hear about the recent tragedy in your family Brian. My prayers are with you and your family. Be safe on your trip, we'll see you when you get back.
  43. Dream
    +1, sorry to hear Brian :emo:
  44. Vector
    Vector Rally Organizer
    Brian, when you get back.
    2002 WRX Wagon
    passenger side fender
    front bumper cover
    Both unpainted, I assume?
  45. ShortytheFirefighter
    Hey guys, I'm back :) Hopefully I can go a week without another funeral.
    Mark, I've got both those pieces in stock.
    57704FE010 is the cover, 151.96 + tax and I've got 2 of them.
    The fender is a 57110FE020 and those are 163.16 + tax. I've got one of those, and they'll come unpainted. Thanks!
