Brooklyn Park Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by ShortytheFirefighter, Jul 2, 2005.
  1. Vector
    Vector Rally Organizer
    Know the feeling, unfortunately.
    I'll try to stop in tomorrow morning, Thurs at the latest.
    Thanks Brian.
  2. Vector
    Also,
    Can the color matched pain be bought in enough quantity to spray a couple of panels (HVLP) or do I need to source the paint elsewhere? Midnight Blue Pearl if it matters.
  3. ShortytheFirefighter
    If you're looking at just spraying it yourself, I'd try Welle Auto Supply on Central Ave in Columbia Heights. They can premix paint for you, they can even do a spray can if you want and their prices are really reasonable.
  4. silver03
    fuel filter
    00 Impreza L 2.2L thanks
  5. ShortytheFirefighter
    42072PA010, I've got 7 of them in stock and they're 21.26 + tax. Thanks!
  6. Vector
    Thanks Brian. Brett hooked me up with the fender and bumper cover yesterday.
    Good thing about wagons, you can use them to haul their own body pieces after you smack them into a truck.
  7. Chuanpreza
    Chuanpreza New Member
    brian, I want to drive up and get the belts today. you still have them in stock? Ill have you take a peak at my car while your at it to check the belts.
    can I get you guys to do an oilchange while im there to? between 5-7?
  8. rsverv
    rsverv Well-Known Member
    Brian, do you have any front sti group n strut mounts (B0310FE000) in stock? lmk, thanks!
  9. hakstern
    hakstern Member
    Hey Brian,
    Can you give me a price for a roof skin for a 2.5 RS 1999 2dr. Let me know ASAP please. Thanks
    -Bryan
  10. ShortytheFirefighter
    Rsverv, I've only got one on hand. I can have another one here by Monday. Thanks!
    Bryan, the roof skin is a 53600FA060 and they're 246.74 + tax (List is 308.42). I would have to order it in, neither we nor Tonka has it. Thanks!
  11. rsverv
    i'll be there monday to pick up the set thanks!!!
  12. EtchyLives
    EtchyLives Well-Known Member
    Need the prices for the following stuff:
    1. 4-pot (07 WRX will work) calipers.
    2. Brackets for said calipers
    3. 2 Front Rotors
    4. Necessary bolts (control arm -> Bracket and Bracket to Caliper)
    The Bonus check is inbound, and daddy needs some new pads and rotors, anyway.
    This is by no means a commitment, I'm just shopping at this point.
    -Your Favorite Old-Skool Legacy Owner.
  13. ShortytheFirefighter
    26292FE041 and FE051, 266.10 + tax each, special order
    You won't need brackets, it's all one unit :)
    3. 2 Front Rotors
    26300AE061, 71.96 + tax each, in stock
    901130011 x 4 3.56 each + tax, in stock
    You'll also need a set of pads unless you're going aftermarket. OEM pads are 26296FE070, 115.96 + tax, special order.
  14. EtchyLives
    Will these fit under 15x7 wheels?
  15. ShortytheFirefighter
    It's going to depend on the wheels. There are certain Rally wheels they'll fit under, keep in mind those are usually 1200 or so for the set. Most 15in will not fit though.
  16. EtchyLives
    The ones I'm looking at are 15x7 +48 and are expensive. Hmm....
  17. rsverv
    pm'd you Brian.
  18. ShortytheFirefighter
    Hey everyone, I'll be in the office from now until around 4ish, so if you need to get a hold of me for parts I'll be around :)
  19. silver03
    Fender Liner 00 Impreza, pass side front. thanks
  20. MNAutomatic
    MNAutomatic New Member
    Looking to do a hybrid this winter and am wondering what the price is on a 2.5 short block?
  21. ShortytheFirefighter
    59110FA000, 16.94 + tax. I'd need to order one or pull one from Minnetonka. Thanks!
  22. ShortytheFirefighter
    10103AB750 (This is for the 07 shortblock), 1688.74 + tax. I'd need to order that in, just let me know. Thanks!
  23. silver03
    fender liner
    B, I'll take one please. Also, same car, are there plugs?, grommets? that can fill the holes in the fender where the intake was originally routed? It now has a CAI. thanks Rick
  24. bisache
    bisache Active Member
    Brian, can you please PM me the price on 04-05 sti fog light covers and side splitters? Could you also tell me the paint code for a psm car. Thanks
  25. Paul Revere
    ^ Looked at my touch up paint right on my desk ... code no. 01G if that helps i dunno
  26. ShortytheFirefighter
    Bisache, you have PM. And yes, 01G is the paint code for PSM.
  27. ShortytheFirefighter
    Rick, your liner is here :) It's on the will call shelf up front. Thanks!
  28. hakstern
    hakstern Member
    I was wondering about the wheeling bearing and seals part# 28016AA030. Would this be for both sides for the rear and would this be all i need? thanks in advance.
  29. driftin240
    driftin240 Well-Known Member
    That bearing is only for one side. You would also need the three seals for the hub. If your only doing one side, then you only need one bearing.
  30. hakstern
    hakstern Member
    well I was reading up on a subaru parts website, with that # I had give, it includes 3 rubber seals. I will just do both sides so they oth go out the same time.
  31. silver03
    fender liner
    I'll pick it up Monday. thanks...any insight to the other question i posed?
  32. EtchyLives
    Riddle me this: What is the part# for the stock crank pulley on the WRX?
    What is the part number for the stock crank pulley on the GC Impreza?
    Is it 12305 AA150?
    How about 12305 AA130?
    I'm looking at the MT pulley and trying to figure out if it is the same between mine and a WRX so I can investigate getting a lightened, non-underdriven pulley.
    Thanks.
  33. ShortytheFirefighter
    There is a blocking plate, but you don't want to block off all the holes, that's where your CAI is drawing most of the air from. I'll have to dig back in the thread to find the part number and price, but IIRC they're less than 5 bucks and I'd need to order one in. I'll have it up for you this afternoon/evening. Thanks!
  34. ShortytheFirefighter
    The 2.2l is a 12305AA242 and the 2.5l is a 12305AA251 on the GC, the GD WRX pulley is a 12305AA242. The transmission does not make a difference in the pulley.
  35. rsverv
    blocking plate
    *fender well blocking plate
    46059FA000 1.86 + tax, special order
  36. ShortytheFirefighter
    Thank you sir :)
  37. EtchyLives
    Thanks, Brian. I'm going to experiment.
    Also, can you guys get the Factory Service Manual for a 94 Legacy SS? How much?
    Something tells me I'm going to need them.
  38. ShortytheFirefighter
    The factory manuals come in different volumes, Engine, Transmission, Electrical, etc. I'll pull up a price in the morning. The volumes on the newer ones range anywhere from 30-80 bucks per. I'll let you know what I find out.
  39. afmoa
    afmoa New Member
    Reminder: special order parts are prepay
    Just a friendly reminder for you guys to keep in mind. You need to PREPAY for any parts that we have to special order in for you. I have had club members order stuff and NOT prepay and NOT come back for their stuff. It is our policy that you must prepay for special order parts.
    Thank you! Brett, Parts Specialist, Morries Subaru.
  40. silver03
    Brian, I need the plastic piece that goes under the front corner of the car (drivers side)...picks up where the fender liner stops as well as the plastic undercarriage protector up front. 00 Impreza. thanks Rick
    B, I was in the area and placed this order friday evening. Could you add on a wheel stud...same car? Thanks
  41. driftin240
    I have a couple spare one's lying around.... If you want to stop by tonka.
  42. ShortytheFirefighter
    Rick, I've been busy this week, I'll have a PM to you tomorrow afternoon.
  43. Chux
    for a '96 EJ22e.
    Engine Gasket set: 10105AA021
    maybe water pump: 21111AA004
    also wondering about a Clutch kit for an XT6 (only numbers listed in my book are for the 1.8l)
    and maybe Loyale radiator: 45181GA631
  44. ShortytheFirefighter
    Engine Gasket set: 10105AA021 217.56 + tax special order
    Water pump: 21111AA004 75.96 + tax in stock
    Loyale radiator: 45181GA631 279.96 + tax special order
    Clutch stuff:
    Clutch cover: 30210AA100 161.40 + tax special order
    Clutch disk: 30100AA195 69.56 + tax special order
    Release bearing: 30502AA002 30.36 + tax special order
    Neither us or Tonka has this stuff, so we'd be looking at next week. Just let me know. Thanks!
  45. Chux
    thanks again. no terrible hurry. this project probably won't be happening for at least a few weeks....
    pretty safe bet I'll be getting the gasket set from you. still unsure on the other stuff.
