Bugeye sedan full lip kit
Discussion in 'For Sale : Car Parts' started by pleiades, May 9, 2020.
  1. pleiades
    pleiades Well-Known Member
    Changing things up on my bugeye so I have some parts that I no longer need. Front lip is Greddy, side skirts and rear lip are C-West, all appear likely to be replica pieces and are made of fiberglass. Mostly in good shape and useable as is (painted WRB as you can see), but not perfect. Front lip has some scraping on the bottom and a crack in the center but not easily visible when installed. The only obvious flaw is a small crack on the upper edge caused by flexing when it bottomed out. The side skirts have some hairline cracks in the paint and a fair amount of sandblasting on the bottom from road debris. There are also a few extra holes drilled in the front surface from mounting mud flaps. The rear lip is in good shape with no apparent issues. Photos to follow shortly of the parts, any major flaws, and of my car with the parts installed. Asking $250 OBO and located near Osceola, WI.
    GrawvyRobber likes this.
  2. pleiades
  3. pleiades
  4. pleiades
    Screenshot_20200509-102429_Gallery.jpg Screenshot_20200426-181909_Gallery.jpg
  5. GrawvyRobber
    GrawvyRobber Active Member
    Think I can get any of these to work on my wagon?
  6. pleiades
    The side skirts should bolt right up but I think the bumpers are slightly wider on the sedan.
  7. pleiades
    They are made of fiberglass though so modifying them to fit wouldn't be out of the question.
  8. pleiades
    Anyone interested in just the front lip? I just posted everything on MnSuBiEz and there's a guy that santas everything but the front. $100?
  9. pleiades
    Autocorrect is in the Christmas spirit I guess.
  10. Krazylegz1485
    How does it attach to the factory bumper cover? Wondering if I could also perhaps fashion it to fit a wagon...
  11. pleiades
    The ends used one screw per side (fairly certain in one of the fender liner screw locations) and the center part that extends inward rests on top of the bottom part of the lower grille opening. I also had two simple sheet aluminum brackets supporting the bottom edge but I'm reusing them for the V1 STI lip, although new ones could be made very easily. Other than that just a couple feet of 3M tape along the sides. As far as fitting it to a wagon bumper you'd probably have to cut it down the middle and take a little out to narrow it.
  12. tangledupinblu
    Or get a sedan bumper and fenders. Dooo iiiit!
    Krazylegz1485 and pleiades like this.
  13. GrawvyRobber
    Yoooo I will def take this off your hands!
  14. pleiades
    You mean just the front, correct?
  15. pleiades
    Front lip is sold, sale pending on the rest of the pieces
